- Ross
- Jul 22, 2021
- 4
- 50
- 161
- Laurel, MS
- 2016 F150 Platinum
- Badlands
2021 Badlands Lux Non Squatch 2.7L 5,500 Miles
Took my doors off for the 2nd time today and had some problems arise for the first time. Might be unrelated but I found it odd that it happened today. Headed home on after an approximate 2 hour trip, several warning lights come on and the alarms begin to go off inside. Service Advancetrac, Check Brake System, ABS Fault, Hill Start Assist Warning and Pre-Collision Assist Not Available. Heard a clicking around my brake pedal and when I pressed it nothing happened. I pressed the brake pedal again and it locked my front tires down so hard that I left skid marks on the road (hopefully haven't ruined my tires). Pulled over, turned the vehicle off and let it sit for a minute or two. Restarted and no issues. 30 minutes down the road and it happened again. This time I pumped the brakes and it was fine. Pulled over, check all the ground wires that I could find to make sure they were tight, pulled the ground from the battery and let it sit for 5 minutes. Restarted and all was well until I was about 15 minutes from my house. Slowed down, kept my distance and brought it on home. Has anyone else had this problem? This is my wife's daily driver and I will not let her get behind the wheel with it like this.
