Scratch Repair
HighFivenWhiteGuy
Renton, WA
2019 Ranger Lariat FX4
Occupation
Engineer
Two days after driving the truck off the lot and someone already scratched it. It seems to be a medium/shallow scratch. Anyone have any recommendations for repair products? I am guessing I will need to clean, sand, polish and buff the affected area with some sort of product or kit. In the past I have had good luck with Meguiar's for other tasks.
joeb427
Joe
Fort Mill/Indian Land area South Carolina
'19 Lariat Sport and 19 Lincoln MKC Reserve
Occupation
Retired
Vehicle Showcase
If your fingernail catches on the scratch, you're kind of screwed.
HighFivenWhiteGuy
HighFivenWhiteGuy
Renton, WA
Occupation
Engineer
Ugh, that doesn't sound good. The scratches shown in the picture BARELY catch the very edge of my fingernail but I found two others that seem to be deeper. Strange thing is that the deeper ones are not as visible and definitely didn't make it to the primer.
I think I am going to try Meguiar's ultimate compound and see how it goes. Hopefully it is enough of an improvement, this is a truck after all and I don't expect perfection.
Strokerduster
Paul
2019 ranger XLT, 2019 Edge ST, 1946 CJ2a street rod, shop full of motoorcycles
Vehicle Showcase
Most dealers have a local "Detail Guy", that does touchup work for them. Usually done mobile, on their lot, and very reasonable. Might be worth asking about.
Jason L
Mount Pleasant, SC
2019 Ranger XLT 302A
I've had some pretty impressive results from Meguiars Scratch X 2.0
Strokerduster
Paul
Vehicle Showcase
I paint and repair some vintage motorcycle tanks and that's an easy fix. Try by hand with a VERY mild compound and don't break thru the clear. It's an easy fix........
HighFivenWhiteGuy
HighFivenWhiteGuy
Renton, WA
Occupation
Engineer
Nice work on the tank! I have a friend who races flat track in the vintage class, has an old TT500 that he works on. Lots of work getting the paint right.
Do you mean a polishing compound? Pardon my ignorance, but I'm guessing the procedure is clean, lightly polish with polishing compound, then apply a wax over the polished area?
Thank you for the help!
Strokerduster
Paul
Vehicle Showcase
Look for something that says removes 1500 grit or finer scratches. I mainly use 3m. No wax until you are satisfied with the finish.
Anthony
Anthony
Connecticut
2019 Ford Ranger XLT FX4 SCrew
Occupation
COO
Vehicle Showcase
Can't give much advice, but I'm pouring out a Diet Coke for you right now.
HighFivenWhiteGuy
HighFivenWhiteGuy
Renton, WA
Occupation
Engineer
I went ahead and tried the ultimate compound and wax, they did a fantastic job! I can still see the biggest scratch if I really look for it but practically it is fine.
THLONE
Thom
Tucson,AZ
68 Chev C-20, 2019 Ford Ranger XL 4X4
Occupation
internet wise guy
Vehicle Showcase
That is why I bought white. Wont show AZ pin stripes as much.
hawk43
South Carolina
wet sanding will eliminate those clear coat scratches....First time takes balls of steel lol...but it works. You tube vids everywhere..Orbital buffer is your friend. good luck.
