- First Name
- Raptor911
- Joined
- Jun 17, 2020
- Threads
- 161
- Messages
- 5,347
- Reaction score
- 11,808
- Location
- Broadlands, VA
- Vehicle(s)
- 2021 F150 Raptor, 2022 Wildtrak
- Your Bronco Model
- Raptor
- Thread starter
- #1
He talks about adjusting the ride height (lift) at the end, but that won't fix the offroad rubbing since that is primarily determined by compressed shock length and not the preload.That Bronco needs more lift, the rubbing is bad.
Let me "showcase" this.And, “Without further ado.”
If it is the same setup in his previous video, it is 4WP coilovers and 17x8+35 wheels. I think this is close to the setup recommended by 4WP, so we now see that the 4WP solution doesn't work well offroad with 37's unless you can accept significant rubbing. I think the 4WP coilovers are best suited to add 35's to non-SAS Broncos (or 37's for street duty). Note that the King shocks are significantly longer and probably fix the 37" rubbing issues, but they sacrifice wheel travel to do that.
Ouch. Couldn't get through the video, all that rubbing was making me cringe. As those 4wp's are adjustable I wonder if he had them cranked up to max height or not? I was originally had a set of the 4wp coilovers but since have decided to go in a different direction.
They are adjustable and he did not have them set in the highest settings. He talked about it in the video
And that's one of the inherent challenges with lifting IFS.
For sure the Fun Haver was cranked down more..but then check out his inner CV boot.
