Should I keep the 255/70R16 tires and the 16" steelies for any reasons?
tongsun3717
X3
If/after installing bigger tires. Or sell them, probably cheaply?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
Should you?
You should know better than any of us. Good luck selling. I’d guess $250 for all 5 if new takeoffs. Much less if used.
tongsun3717
tongsun3717
X3
Should you?
Sell the tires and keeps the rims. Also get to re-use the sensor valves.
tongsun3717
tongsun3717
X3
Don’t know if you get any sort of winter but might be good as a winter set
Yes, we have Winter and Snow in north Ohio, but I am older than the age of replacing tires (DIY).
MallCrawlinBranco
stevo
CO
Subaru Forester MT
Could have the worlds most over the top paperweight collection.
Or if you plan on running aggressive offroad tires you could keep the originals for your commuting miles and swap the big boys on only for trips.
If you can't get a decent price for the OEMs, you could keep them as spares if you ever blow the new ones
Could keep the rims if you plan on running snow tires like others have suggested (winters on the oem rims)
Potentially if you need warranty work where the dealer might blame the wheel/tire combo (unless the new wheels/tires actually caused it, then that is a dick move)
Otherwise I don't see much of a point
MNBigfoot
MN
At least around here OEM take-off truck rims are a dime a dozen, it will be the same way with Bronco's in a year or two. I'd sell them now before the market is flooded. Personally I think the steelies are the best looking rims offered right now from the factory.
tongsun3717
tongsun3717
X3
tongsun3717
tongsun3717
X3
i will sell the tires, use the valves, keep the steelie rims and the bronco center caps. the 255 70 16 bridgestone h/t 685 tires are $186 on tirerack. i will be happy if getting a half of it. but warmart has the same tire for $139.
charlieecho
Charlie
2018 F150 ecoboost
Just went to discount tire this morning to order tires and they said they’d give me $250 total for the 5 set on my OBX. He suggested I could probably get double that if I just sold them myself so I’m going to give that a shot.
tongsun3717
tongsun3717
X3
Room for profit, perhaps a little too roomy.
