Is your bronco cactus gray?
OBX 37"KO2 with 17" 1552 and fabtect
Lift
Oxford whiteIs your bronco cactus gray?
For some reason your wheel looks shifted forward in the wheel well.Yeah bfgs always run smaller than most tires of the same size. Even the red labels. Here is a 39 red mounted up….way to big to run with no lift of course.
Maybe just the angle the picture was taken…just a stock Sasquatch bronco with a method wheel and a 39 bolted to it.For some reason your wheel looks shifted forward in the wheel well.
I’m trying to decide what wheels and tires to upgrade to and I just can’t decide. Can you guys post your broncos on 37’s? Please and thank you!!
This combo won’t work iif you drive it much at all.Would there be any issues running 37s with a 4" lift on a 2.3 BB? If I don't wheel much would I need to re-gear?
I guess I'll stick with my current setup which is 35s with a 2" lift then!This combo won’t work iif you drive it much at all.
Maybe you’re not serious?
Getting on I-35 is gonna be a bitch.
yep…regear….at the very least
What fender flares are these?? Thanks
They are the Air Design from Ford.What fender flares are these?? Thanks
