Burndog
Bryan
Dearborn
2016 Expedition
The bigger selling point for me with Sasquatch is the better setup to eventually have a small lift and 37’s.
I would keep the Sasquatch wheels and the gearing is already there.
if I stuck with the non-Sasquatch I would be kicking myself in a few years when I got the itch to add a ~2 inch lift and 37’s.
Exactly. Upgrading gears is a serious commitment of $$ for parts and labor
bigsky713
Vernon
1975 Ford Bronco / 2002 Ford Super Duty 7.3 PS
2dr looks very good on 33’s or 35’s. But, imho, the longer 4 door does not look as good on the 33’s, like it needs something more. Because I only loose 1 cm of travel I think it was an easy decision for me to get the 35’s, I get the look I want and same capability.
There’s been a lot of comments from others detailing how expensive it will be to recreate the Sasquatch upgrade through aftermarket options. I am convinced I would end up regretting not getting Sasquatch.
I personally opted for the 2.7 fora few reasons.
Ricepuddin
Nate
2017 BMW 340i and 1998 bmw m3
If the 2.7 came with a manual if be all over it, but I am good with the 2.3 and the correct number of pedals. 33s will be plenty for me.
Great photos thanks for sharing
grewhi
Greg
Seattle, WA
Maserati MC
Something not right here. In the front view the stud Bronco is Race Red and in the side by side the 35" is Rapid Red, I can see the Race red in the background and it looks substantially taller. What gives? (could be the second Bulleit as well)
broncosor
broncosor
2022 Bronco Badlands
took both photo at a different time. The Broncos were riding all day. The race red is a Wildtrak and the rapid red is a first edition. Both exact same height and tires. The reason you think the one in the back look taller is perspective. They are the same.
The 2 Area 51 badlands are also different. One is on 33 OG and one on upgraded 33 wheels.
Gamecock
@broncosor , I know you said you crawled under to look at the Badlands skid plates...how heavy duty did they look? Did they look like something you could drag over rocks, or would they need to be replaced with heavier plates?
HoosierDaddy
Indiana
Aftermarket 33" with 0 offset it is!
Getting out there with them tires! Gonna need some WiiiiDE flares!
Assuming wheel width remains the same.
+55mm offset to 0mm = 2.16" (pushes wheel out) or (increases backspacing by)
+30mm offset to 0mm = 1.18"
If I understand it correctly, Sasquatch wheels are +30mm offset. All others are +55, except possibly Base as I didn't see pics for those wheels.
Backspacing no greater than 6.6" should be what your looking for....if I understood it properly.
Djdmustang
Darren
Orange County
1965 mustang
How easy is it to modify Squatch and add 2" of lift to add 37's. I'm with you that I prefer the Squatch out the gate.... but you cant add 37" tires on standard Squach. Is it possible to modify and lift the Squatch package or will you replace so many parts that its not worth doin so. Just asking, I dont know the answer.
AMICHDEC
Andrew
Indiana
Infiniti
It’s definitely a dilemma for me to decide between squatch or non-squatch on the badlands. I think it’s easier for some to squatch when they are going with a different trim other than badlands due to a different base suspension. I don’t care for the 17” beadlock capable wheels to be honest and will plan to upgrade to a 20” wheel (likely method or rhino) with better offset wrapped with 35” on my badlands. Also, Ford performance will undoubtedly come out with a suspension lift similar to the one offered with the Ranger if more height is wanted. To each their own.
Erock
US
2018 F150 Alpine edition
I’ve modified every truck/bronco I’ve owned... so I just went with the 33s on the badlands knowing I’ll be changing them. Not overly interested in any of the wheels offered, so I’ll pick my own.
Zeke013
Oregon
This is where I am.
Manual requires 2.3 and 33"s (today), so there you have it.
Zeke013
Oregon
Brichan
Bill
Ram 1500
Hank 615
Henry
Nashville
2015 Mustang GT Premium, 2023 Bronco Badlands
Sasquatched Badlands may have restricted travel because of bumpstops but they're just bumpstops. Just crack open the parts catalog, order some standard Badlands bumpstops and spend a few minutes swapping them out. Worst case scenario you get a tiny bit of rubbing in the wheel well at the very top of your wheel travel.
