WeirdGuy
Austin
Galveston, Texas
Base Sasquatch
Curious... What about just replacing the bulbs in the rear to LED? Since the front lights on ALL models are LED, then there shouldn't be any hyper-flash in the rear after bulbs are switched. Switching them to LED bulbs would at least give you a brighter and cleaner light look.
Gangstead
'21 BD 4DR 7MT Soft
What's the process for swapping them out? How much disassembly do you have to do to get the headlights out?
jag18888
jag18888
Philadelphia, PA
I used this video.
It took about an hour all in with simple hand tools, not including the 30 minutes to run to the hardware store to get a Torx Plus 40 to remove the Brush Bar.
King_Bronco0327
Orlando
Hi all - there has been a lot of discussion about cross-compatibility, especially on the BD since the signature lights are not a factory option. I can confirm the Signature headlights can be swapped with the Standard headlights on the Black Diamond. The pin configuration is slightly different but they plug and play in the BD with full functionality and no fault codes.
YES. Basesquatch here I come.
how did you get them? Did you purchase directly from the dealer. And if so how much did it cost?
Gary
Gary
Subaru Outback
Thanks for posting
Rcantu65
Robert
Houston
2021 Bronco Black Diamond
Did you have to re pin it?
Tornado_735
Aaron
Oregon
19 Silverado, 18 EcoSport 4x4, 09 Aveo, 1995 P38
I would suspect it will hyperflash with LED bulbs since the wiring between the two is different...however, I am going to have one of the guys at work check and see if hyperflash can be disabled like on the Super Duty.
WeirdGuy
Austin
Galveston, Texas
Base Sasquatch
Thank you. Will definitely be interested in reading what you find out.
Jabberwock
Craig
Georgia
2011 Toyota Tundra
I’m doing this very thing. There’s one company that makes an LED bulb that is compatible. The bulb type is WT21 and is white on the stock unit. They actually sent me the WTY21 by mistake which only has two pins instead of four and would work for the backup lights if it were white (I ordered red before I knew the stock bulb was white.) I will likely replace the stock backup bulb as well at some point if I decide not to go with a pod or flush mount backup light because they don’t seem bright enough to me. The bulbs were shipped directly from the company and they are out of stock for another two weeks on the WT21.
I’m not sure why Ford is going with this proprietary bulb. Maybe someone can chime in and explain. I believe it was also used on some more recent F150s. It looks very much like a 3157 but supposedly is different in some way, possibly in dimensions.
Alla Lighting WT21W LED Bulbs,... https://www.amazon.com/dp/B0973LTWQ4?ref=ppx_pop_mob_ap_share
You can also order them directly from the manufacturer.
WeirdGuy
Austin
Galveston, Texas
Base Sasquatch
Thanks! I will definitely be ordering these when my Bronco is finally delivered.
Djd7
Northeast
BD
Tried. Results in hyperflash for the blinkers. Let me know if you know of a fix besides resistors
Jabberwock
Craig
Georgia
2011 Toyota Tundra
Bummer. I’ll see if I can figure something out. Thanks for the warning though.
Jabberwock
Craig
Georgia
2011 Toyota Tundra
Anyone know where the turn signal relay is located? I’m wondering if modifying the relay as outlined on this linked page would work in preventing hyperflash without needing the resistors.
https://www.ford-trucks.com/forums/1479725-led-turn-signals-and-hyperflash-fix.html
My other thought is has anyone ever wired the stock incandescent bulb in parallel with the turn signal wiring just like a load resistor? This would run MUCH cooler than a load resistor and could be hidden in the area behind the turn/brake light housing.
