- Joined
- Jul 9, 2020
- Threads
- 31
- Messages
- 1,758
- Reaction score
- 4,161
- Location
- Pittsburgh
- Vehicle(s)
- 2018 Honda Pilot
- Your Bronco Model
- Badlands
How do I switch models? I'm on Android and don't see a way to do it. Im stuck on base two door.
I just tried it on my android phone, you should be able to just tap into the trim column (ie Base 2 Door) and the trim list should appear. Then you just tap whichever trim you want.How do I switch models? I'm on Android and don't see a way to do it. Im stuck on base two door.
That's very do-able.Ford Super duty up fitter switches $165 https://shop.ford.com/build/superduty/#/config/Config[|Ford|SuperDuty|2020|1|1.|610A.F3A.142....XLL.REC.YZKAA.SRW.350.CBC.]
Great job! Granger says %3 off veicle and %6 off packages will get a price very close to invoice. Any chance you can add that to get the X-plan pricing ?As the title says, I made a little price estimator in Google Sheets. You pick your trim, the packages you want and add any options you want and you can see your prices.
There are 2 sheets if you look at the bottom when you open it. One is the Tool itself and the other is a ReadMe that explains a couple things. Check out that ReadMe.
A few things of note. Columns are labeled as:
I verified my loan calculations against Google's auto loan calculator and they match. So you should be getting a pretty accurate view of your cost (based on your option estimations of course)
- dropdown (you click the dropdown arrow to see selection options)
- calculated (column is not meant to be edited/changed and will populate automatically)
- user input (you are able/supposed to enter in your own values here)
Follow the link below. You'll be asked to make a copy so that your edits are your own
TK Build & Price Estimator
Let me know if you have any problems, requests or whatever
Thanks! I’ll check it out.I added a Trade In column where you can enter in your estimated trade value. All new copies should reflect this change. Let me know if this is the calculation you'd expect.
Thank you!
I thought the AUX switches were standard, at least in the Black Diamond.I am hoping that the aux switches will only be $100 like in this spreadsheet.
They're standard with black diamond but I have pretty much decided I'm going base squatch and adding the switches.I thought the AUX switches were standard, at least in the Black Diamond.
I received my Mustang card in the mail. I think i need to initiate the PIN 2 months in advance from when we order in January? Should i just do this now? Or is there a benefit to waiting?I agree with that because there is no Bronco B & P to use the X Plan on at this time. That's why it said to watch for updates. Only time will tell.
