Snow Traction | Badlands Tires v Sasquatch tires
SamG
Sam
Detroit Area
sas
Apologies if this has been discussed at length.
We know the size difference, we have a general idea on weight difference etc...
do we know which set of tires will handle better in the snow?
I know neither will be better than a true Winter tire, but I'd like to not throw another $1500 immediately at this truck for snow tires, so I am wondering which set would perform better.
any ideas?
IMO the sasquatch tires appear to have a tread pattern that makes more sense for snowy conditions, but then again I know very little about tires.
Jdc
Jon
Massachusetts
Bronco Badlands
Mud tires aren't the greatest in snow but as with anything that's going to depend from tire to tire. All-terrains would be the better choice for snow
BeerForMyHorses
Jared
Idaho
Ford Bronco 2-Door
Tread doesn't make a huge difference in snow, because snow and ice will pack into the tread. What makes the difference is a skinnier tire to cut through the snow (hence the commonly used name "pizza cutters"). In general, I would say mud tires may not be the greatest choice for snow.
Also, since the Sasquatch Goodyear tires have literally never been used, you're going to get the cliche "no one can know yet" answer. I personally will go with the stock Badlands tires which I believe are BFGoodrich A/T KO2s. The KO2s set a high standard for what a good all terrain tire should be, and do well in the snow. If it doesn't come with KO2s, I'll put those on
Jdc
Jon
Massachusetts
Bronco Badlands
Yeahhh....That's not true. Mud tires are not good in snow.
http://knowhow.napaonline.com/winter-wheeling-can-you-use-mud-tires-in-snow/
https://simpletire.com/learn/tire-maintenance-safety/how-do-mud-tires-perform-in-snow
BrentC
Brent
Calgary, AB
The K02s are snowflake-symbol rated. They work in the snow and ice. Take it from a guy who drives to the ski hills all winter.
Bigmoose
Jon
RI
2019 Flex Ecoboost Limited
The biggest factor is temp rating. The softer the rubber at cold temps the better. Sounds like they improved the BFGs. The original A/T KOs were like driving slicks in the snow.
Gamecock
We really don't know yet...Goodyear stated they were going to test the new tires for the 3 peak snowflake, but I haven't seen results. The KO2 has the symbol and they are decent in snow. The Goodyear actually looks to have more siping than the KO2, so I am optimistic that it is pretty good in the snow. We will have to wait for testing and reviews or real world experience to really know.
@BadBlueBronco
Kc
Los angeles
I feel like I read awhile back that the MT tire for Sasquatch stands for “maximum traction” not “mud tire” like it normally is. I agree confusing.
as far as snow tires go, you want snow to build up a bit. Mud tires do too good of a job at ejecting snow and also have a rubber compound that gets too hard in the cold.
ronstar
Ron
Illinois
F-150, Jeep JL
It’ll be tough for those Goodyear’s to be as good as KO2’s in the snow. I got KO2’s on my F-150 about a month ago. I took a ride during 4-6” snowstorm. Ended up driving 1.5 miles of untracked whatever (didn’t show up as a road on the nav system) - no problem at all 30-40 mph through it all. No traction loss at all even without any weight in the bed. And in 2 wd.
rtsherry73
Richard
Boynton Beach, Florida
Toyota
Here ya go, best ever snow tire. Original equipment 1975 tires (I think 1975....) Rode like crap, made noise, but never stuck in snow. NEVER.
Ford Bronco Snow Traction | Badlands Tires v Sasquatch tires A A A Bronco Pic
BrentC
Brent
Calgary, AB
Texas-sized 10-4 on this comment! The early-generation A/T T/As would work pretty good in snow until about half-worn through the tread, then they turned into bricks! The new ones I run all winter with confidence.
BeerForMyHorses
Jared
Idaho
Ford Bronco 2-Door
