So I Found Out Friday Afternoon... While driving in pouring rain with the top off
stickshifthappy
RVA
Ford Ranger, 65 Mustang
Not sure if you are joking, but that’s definitely not how a forecast works. It’s a formula based on the likelihood it will rain in the area and the percentage of the forecast area that would be impacted.
https://www.weather.gov/media/pah/WeatherEducation/pop.pdf
Well, If it says 15% chance of rain, and I'm planning on driving with the top down, playing softball, fishing or camping (especially camping) ... it means that it will 100% rain on me....
AMC Ape
Bronco L
Oregon
2023 Bronco Badlands, 2021 Hyundai Tucson Ultimate
This is why I am little bit less fustrated getting pushed to 2023, I added the retractable front row twill soft top to my build.
RoLyMa27
Rodney
SloKart, TX
21 Bronco, 22 Maverick
I learned Friday the media screen spazzes out big time when it's soaked. Try to avoid that.
And...this is from a "trusted source", the resonant frequencies transmitted up through the cabin at precisely 58 mph when you're running tractor tires, shakes the juice right out of the capacitors, causing your radio to spazz out!😉🙃🤪
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
I've been caught in a couple of downpours with the top and doors off. You get wet. Water accumulates on the inside of the windshield which can make it hard to see. That's about it.
Biggest problem I have is all the dust turns to mud. No problems with the screen or anything else not working correctly.
SurfsUp85
Joshua
Windsor, Ontario
youtube.com
2021 Bronco 4 door Outer Banks, Kia soul 4u
That if you have friends in from out of town, and you plan a day trip/hike that's 2 hours and 15 minutes from the house, and the weather says "15% chance of light scattered showers" and you take the front and center panels off that-
A: It will rain. A lot. Like, starting right before you come off the trial, and then the entire 2 hour and 15 minute trip home.
B: No matter which way you're going, the storm is going that way, too.
C: You should try to maintain a speed of at least 50 MPH, and the rain will mostly avoid coming in the cab of your Bronco you've had for 3 weeks.
D: If there's nothing you can do to stop it, you should just try to make the best of it and sing songs really loud. So you don't cry.
Oh, and
E: You'll see another Bronco on I25 with their soft top on, and they will point and laugh at you.
Solid post!!!
UNBROKN
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Not enough room in the back for tge panels?
I know OP made a comment on your post, but I will elaborate a little more. Front panels in the bag, dogs probably could have fit fine too. Middle panel has to have the seats down to fit in the back and it fits back there kinda tight. No passengers and no dogs.
Dubsesd
Andrew
CT
04 Ford F-150, 06 Roush Mustang
Happened to me on the highway, had top down all doors off all of a sudden sky went dark and down poured! We were soaked. We stopped at the next rest stop and put top up. Makes a good memorable story.
Dino
Dino
Dino
2011 Ram 1500 4WD
HoosierDaddy
Indiana
I don't know for sure, but I'm thinking even one of the mesh tops MIGHT help a bit at the stop lights, slow going, etc.
I know the canvas/vinyl top on my 69 saved my bacon a few times. You had to lean away from the edges at the stop lights, but once you were moving, it was dry.
kodiakisland
Arkansas
What? Heck I ride my motorcycle into the mid 30’s.
34 degrees is my cutoff for commuting to work on my bike. Once it gets below 40 degrees, I switch to my winter gloves and put the liner in my jacket. No wind screen or heated gear.
As far as the Bronco, the lowest I've done is 20 degrees at 80mph with no doors and top. Not comfortable for most people for sure, but for a short drive I can deal with it.
HoosierDaddy
Indiana
@kodiakisland 's Bronco when he gets to his destination.
Ford Bronco So I Found Out Friday Afternoon... While driving in pouring rain with the top off 1664766850512
Here he is...
Ford Bronco So I Found Out Friday Afternoon... While driving in pouring rain with the top off 1664766932693
jason9m9
Charlotte, North Carolina
2017 Chevy Camaro
We had our two dogs with us, so there wasn't enough room. When it's the two of us, even with the dogs, there's enough room and we can put the seats down.
Even without the dogs isn’t it true that if you have 4 people and can’t put the backseats down you can not fit both the front panels and mid panel? If so I just feel like that was a small oversight in the design unfortunately. Like if I have 4 people in the vehicle I want both panels off and ideally I’d like to be able to bring the panels with me somehow just in case something like this.
kodiakisland
Arkansas
Design oversite, as in they should have made the Bronco bigger? At some point, you can only put so much stuff behind the seats.
