SO MANY QUESTIONS! How about some answers?
Carolina Jim
Highlands
2021 Bronco 2-door
I've seen nothing in the 2-door technical specs regarding Auto Stop/Start. Anyone else???
Its mentioned numerous times in Bronco Sport specs.
cowgoesmoo
Hayward CA
07 Mustang v6
Curious if 33's won't be available as an option on something like the outerbanks.
On the pdf sheet it states that it comes standard with 32s but the 35s are optional. nothing about 33s, this is from the pdf sheet you get when you click on compare the models. However, I'm not sure if this is finalized considering there's still half a year left to start the ordering process.
xmod
2017 GT350, Toyo 4Runner TRD, Badlands
Why no 2 dr soft top? Will Ford sell you multiple hard tops (white and gray)?
xmod
Can an insider confirm they are going to offer a tune for the 2.3 engine?
xmod
Also, I would really like Ford to offer a nice set of canvas seat covers since I'm getting leather seats. Something as nice as the badger coachworks seat covers they make for the land rover defender.
codydb19
Cody
Silverado
Haven’t seen it mentioned, but I feel like I saw a button to turn it off in one of the interior pics. So yeah I would say we’re getting it. At least they’re giving us a way to turn it off.
Edit to include pic
Ford Bronco SO MANY QUESTIONS!  How about some answers? 579A1746-3DDC-4DF8-BAA1-6D8BA603CADD
dmo1028
2019 Tacoma TRD Sport
Edit to include pic
I'm not familiar with the Ford start/stop system, so my question is do you have to turn it off each time you turn the ignition on or does it keep the last known setting?
codydb19
Cody
Silverado
I’m not either, but I’m assuming since there’s a button it would have to be every single time. I’m only familiar with the GM system and there wasn’t a button at all.
OCDON
Don
Ocean City, NJ
2013 Wrangler
You have to switch it off every time you start the vehicle to keep it from auto stop/start.
dmo1028
Gotcha, a button is definitely better than no button for sure! My wife’s Jeep Cherokee requires a push of the button every time, which is a pain. I had a BMW that retained the desired setting until you told it otherwise which was awesome.
codydb19
Cody
Silverado
Yeah and I assume if it’s a big issue for anyone it would be relatively easy to install some kind of permanent defeat.
Also I assume the Ford system works the same way, but my ex-gf’s car had it and if you had the AC blowing it wouldn’t shut off. And down here in Texas you run the AC so much, even in the winter months, it was hardly ever an issue.
Carolina Jim
Highlands
2021 Bronco 2-door
wvmtneer
‘Merica
F-150
but if you want Position Sensitive Dampers you have to step up to Badlands, unless you go Sasquatch
Looking at your profile and vehicles I doubt you have ever owned a Bronco. I have owned three, and have been active in the Bronco community for years, and trust me even in the Classic Bronco world most don't do any hard core offroading. If I go offroading it isn't hard to put some all weather rubber mats in it
Mall Crawler.
DonsBronc
Don
2017 GT350
If you want a Wildtrak without Sasquatch? Get an Outer Banks
33's and carpet? I'm sure you will be able to order a Base, BB, OB with larger tires. If not, put them on yourself after you take delivery.
BB & OB come standard with 32's. Is 1" really going to be that noticeable of a difference?
Ya I looked into a Outer Banks, but it only has 4.27:1 gears so if I go up to 33's it will be geared to high. I want the 4.46:1 gears, and you can't get the Bilstein Position Sensitive Dampers on the Outer banks. I was excited about getting back into a Bronco, but if I can't get it the way I want, I really don't need it that bad. The more I look into it the more it looks like I won't be getting a Bronco.
It's OK I have a GT350 and a C63S so I think I'll survive
