So... Squatch means no roof rack. Changing your mind?
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #1
So it clearly not a GVWR thing, as you can't get a roof rack on a Squatched base 4 door with 2.3, same as you can't get it with the V6 on any other squatched trim. So a dynamic vehicle weight/center of gravity thing?
You can add rack to a Squatched 2 door though!
Canada doesn't get the FE... Did I read that you can add roof rack to a 4 door FE?
So...are you adding your roof rack after ordering? Giving up on Squatch? Going 2 door instead of 4?
BroncoJay
Iowa
Tacoma
Ya a roof rack would not be a deal breaker for me, too many aftermarket options. But I’m going with a 2 door WT and I get to add the rack as an option... so there’s that
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #4
This question should have be ask in the stupid question thread!!!
Lol. Well I know it won't be a deal breaker for anyone...
I guess I just wanna know Fords reasoning in it...
Pretty stupid, yes...
Drex
Jake
So it clearly not a GVWR thing, as you can't get a roof rack on a Squatched base 4 door with 2.3, same as you can't get it with the V6 on any other <4-Door> squatched trim.
I made your statement less confusing by adding <4-Door> to it. As you later state it works (and I verified) with all 2-door configurations.
The 4-door weighs right at 200 pounds more than the 2-door. It also has an additional seat which means another (guessing 170lbs) of calculated person weight over the 2-door. That is 370lbs of extra GVWR used up right there.
You have it backwards, it is not the theoretical weight being too high up, otherwise it would not be offered at all, it makes far more sense that it is the total weight. the 2-door can automatically carry 370lbs more of accessories than the 4-door right out of the box if the limit, as Ford has stated in the FAQ, is related to going over the GWVR. (in Sasquatched form)
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #6
That makes more sense... But it also must be partially a dynamic center of gravity issue as well, as the 4 door non-squatch can have factory roof rails...? Confirmed on 4 door BL
Edit: oops... forgetting the additional weight of the Squatch pack
Markubis
New Hampshire
Ford Focus, Ford Ranger XLT, Can Am Ryker
Don't worry. Ford will address the roof rack on 4 door squatch next year at the updated build and price.
:unsure:
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
  • Thread starter
  • Banned
  • #8
Just how heavy are the HD bash plates??
On a 2 door WT, you can not also add roof rack with the bash plates! Jeezus Ford
Rubisquatch
Pittsburgh, PA
2021 Bronco Wildrak
I wish Ford would give us a very clear and exact answer as to why. This is the part that pisses me off. Tell us exactly WHY? Is it GVWR or something else? Same with sound deadening, pain’t protection, etc. This is just REdiculous.
Rant over - Anyways, I’m just getting the rack from parts and putting it on myself.
  • Like
Reactions: Axe
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
Yeah, really... Paint protection film weighs that much? Exactly how close is this thing to Max GVWR out of the box? 3lbs?
WuNgUn
WuNgUn
Ontario Canada
2 door Squatched
So a 2 door WildTrak can't be had with bash plates and roof rails... Can't be a weight issue because you can add roof rails to a Squatched Badlands! (with auto and 2.7)
Crazy
mneblett
2018 F-150, 2019 Mustang GT vert, 2019 Corvette
Not changing. We're currently planning on going with the soft top, and waiting to see what the aftermarket comes up with for a removable rack solution. We will only occasionally need a rack, so a non-permanent rack mount would allow us to continue to use the soft top most of the time.
pineapple
Cass
Philadelphia
Subaru WRX
As in no roof rack installed from the dealer or they recommend no roof rack at all?
Roof rack is a must for me as a tent (GFC ultralite) is going on top.
BroncoT
SUV
GVWR makes some sense since they could be trying to keep the vehicle in a specific weight class for whatever reason. What doesn’t make sense in this scenario is that you can add accessories to your heart’s content. heavy accessories.
For example, the pull out tailgate is likely 20 pounds heavier than sound deadener. And they’re all removable so that shouldn’t matter either. Light bars, pods, tents, that weird fishing thing. I feel like Ford is getting marketing cute here trying to give little wins through all the various choices.
none of these things are going to change my build so I’m not worked up. sure, I’d prefer to give Ford money for their roof rails and sound deadener, but it’s not like I won’t have plenty of nice options for likely cheaper with just an ever so small bit of patience.
Hemisfear
Bronco Bob
Lotusland
2014 Focus ST
Nope, rocking 2 doors, but I’d add one after if I was going 4 door!
