As always, you are a ray of sunshine. Oh wait...im just asking if it will be able to carry this stuff or flip over
and asking why ford would design such a shitty car
This thing will absolutely flip over if you ever make a right or left hand turn. Cancel your res now and Run for the hills!im just asking if it will be able to carry this stuff or flip over
There is no telling, other than they don't want you to buy, run! (Please post cancellation info with date in "cancelled reservation master thread" Thanks!)and asking why ford would design such a shitty car
right but the GVWR for these jeeps is almost double that of the bronco
Correct. 35% more payload on a JLU Rubicon vs 4dr BL 2.7Do you even math bro? Almost double the GVWR would put you squarely into one ton territory. There ain't no Jeep with that kind of capability.
This type of crap is getting g real old on this forum. I can't wait until the Bronco starts getting into owners hands that really want them. People who post this crap should just go buy something else that they can get right now.im just asking if it will be able to carry this stuff or flip over
Don't order the full rack of Brontosaurus ribs and you won't flip over.im just asking if it will be able to carry this stuff or flip over
I don't see this as an issue. Rather it is all part of the build. Most of the overlanders have: 1) put in heavier springs along with their lift to manage the load, and 2) upgraded to bigger brakes (on the JKs at least).Youtube jeep overlanding. Don't tell me some of those loadouts are under their GVWR!
Definitely wear good shoes though so that you can stop!Don't order the full rack of Brontosaurus ribs and you won't flip over.
this clears up alotPlease stop. You are confusing terms and when you repeat this nonsense, it just gets worse with other people who rely on it. GVWR is the maximum total weight of the vehicle and stuff in it (close enough).
You appear to mean that the payload (the stuff that is not bolted to the truck) that can be carried is lower in the Bronco than in the Jeep. That is because they both are extremely likely to share a 6000lb GVWR and the Jeep is lighter than the Bronco. The weight difference between the two is the extra weight you can carry in the Wrangler. It is not a measurement of stability (tipping over) with weight.
"Payload" is what you're looking for not "GVWR"right but the GVWR for these jeeps is almost double that of the bronco
The Jeep payload isn’t really all that much more. Mine was 840, jump over to the Jeep forums and search payload and/or GVWR. Lots of complaints from sub 1000lbs. People just don’t realize the published maximum payloads are for the base stripped down models.this clears up alot
so what you are saying is because the jeep is lighter it has a higher payload rating (AKA until insurance starts getting iffy)
not that it can literally carry more than the bronco.
the payload for the badlands is way less than 1100lbs based on that other threadCurb weight + payload = GVWR
GCVWR is the max vehicle and trailer weight, tongue weight becomes part of the payload figure.
We know the curb weights and we know the payload, so we know the GVWR.
Really though, to answer the OP overlanding question, you just need to know the payload, and where you can place that load. The roof supports 110 lbs. while driving (dynamic) and 600 lbs. while parked (static). We know the payload is 1,170 lbs. (2-door) and 1,370 lbs. (4-door). We know the tow rating is 3,500 lbs. and the max tongue weight is 350 lbs.
So, you should be able to answer all of your weight related overlanding questions with that info.
@beachman101 insurance has nothing to do with it.
