This squeak and rattle started about two weeks ago after 3 months without any noise. The noise is coming from the back corner.
anyone else hearing a similar thing?
Hi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.I know this thread is almost old enough to vote - but I just now started having this issue.
Right at 6,000 miles and right as the weather warmed up here in Michigan.
For me its the front drivers side, horrible squeak that sounds a lot like two pieces of Styrofoam rubbing together. When I have the first section of the roof open/flipped back the sound goes away. I thoroughly investigated the squeak area and can't really figure out what's going on....
Having the same issue, was this ever fixed? So annoyingHi there! Would you send us a private message with your VIN and dealership name and location? I’d like to look into this concern on my end.
ME TOO!!! And it's driving me bloody nuts.I have the same squeak when my soft top is partially open from the latch on the top where the soft top connects to the frame. Just started this past week and probably have had the top down over a dozen times
Good morning! Could you privately message us your VIN and the name and location of your Ford dealer so I can look into this noise concern for you? Thank you!I have 4,229 miles and a squeaking recently started when the soft top is back in the first position. Driving me a bit crazy. Seems like it’s coming from the driver’s side. Need to figure this out.
Hi, I’m having the same issue. Curious. What did the Service dept say? Thanks!Same for me, just under 7000 miles and squeaking when open in 1st position. Seems to be coming from at/near where the 2nd position latch is. Driving me nuts.
I have an oil change and tire rotation coming up on Monday, so will mention to service dept then
