Some Texans use 2021 F-150 hybrids onboard generator to power homes amid winter storm
Lilj4425
Jacob
Greenville, SC
2021 Badlands Bronco
DeltaBravo
Delta
MIKES MOM
Yeehaw Texas
BigHoof
PA
Ram 2500
I guess that will work till you run out of gas which will probably also be in short supply if no electric to power the pumps.
BlueBronco
DFW
I didn't realize they had a 7.2kW option. That's a good size generator, although, not very efficient if it is powered by 6 or 8 cylinders. Would be cool if it had "generator mode" or something that would prevent theft and also deactivate cylinders for better efficiency.
And if anybody does this or uses a a regular generator to feed their panel, please make sure you install a transfer switch that prevents you from sending power into the grid.
Edit. More info
Edit2. And now you got me B&Ping a new F150, the new ones even have their own version of GOAT modes (mine has normal/tow/sport) so thanks, thanks a lot
Nickp
Nick
Phoenix
Car engines are actually surprisingly efficient to use as a generator. TFL charged a Nissan Leaf with a powerboost F-150 and it used 3 gallons over 3 hours at max capacity basically the whole time. And all it does is idle. Just looking around it seems like a gallon per hour sounds just about right for an actual generator.
Portapot
Maryland
Cj7, RX350, f250,
With the bronco delays I was considering this vehicle with the 7.2Kw generator for this very reason but then I thought when will I really need a generator. I guess those guys in Texas are pretty pleased with their decision. This is very cool
Headsong
First saw this yesterday from jalopnik...
Nellman
Josh
Northern California unfortunately
2007 Toyota Tundra
Fo
Ford did think of this to prevent theft of the vehicle. I would have loved to get an F-150 King Ranch but can't justify the $75k cost for how I would want it. Bronco will be great and keeping my '07 Tundra.
Lilj4425
Lilj4425
Jacob
Greenville, SC
I wonder if something like this was offered in the Bronco and Ranger if it would attract more overlanders?
I am very surprised Ford doesn’t offer this feature in the Bronco and Ranger. Seems like a no brainer.
TXNavy
Christopher
Spring, TX
GMC Yukon XLT 1500 4x4, Jeep Liberty Limited
The Ranger I can understand with its open bed but the Bronco may have issues due to the generator having to be inside the cabin.
BroncoBuckaroo
Joe
Missouri
2017GT350-SOLD, 2013 Ford Edge, 1969 Torino Cobra
