Sorry for the newbie question - which exact part is it? BORA 6 lug (plastic?) spacers?
This one in the middle?
21-22 Bronco BORA 1.50" Wheel Spacer Set 21BRONCO1.50X4 (stage3motorsports.com)
LOL I misinterpreted the whole thread. You are talking wheel spacers. Have at it no issue there! However, I will say I definitely noticed a little vibration when I used spacers on my Tundra, and those were hub centric perfectly machined spacers from Spidertrax. I ended up not liking the high speed vibration and just bought new wheels that did accomplished the same thing without the issues spacers can create, especially cheap ones that are not machined perfectly for your hub diameter.Sorry, I am not smart enough on this kind of stuff. My rig will be mostly daily driving in MN but I will not shy away from the opportunity to take off road when possible but it’s not like I’ll be in Moab. So, if I want minimal spacer for a cool wider stance so maybe 1 or 1.5 inch spacer, do you think I will run into mechanical issues? Likely not lifting or going to taller tire until warranty runs out, but when these tires wear out I will likely get some beefier wider tires. Thanks for additional input!
Haha got it, thanks! I went with 1 1/4 bora. Hopefully that is short enough and good enough brand not to have any issues with.. here’s to Friday!LOL I misinterpreted the whole thread. You are talking wheel spacers. Have at it no issue there! However, I will say I definitely noticed a little vibration when I used spacers on my Tundra, and those were hub centric perfectly machined spacers from Spidertrax. I ended up not liking the high speed vibration and just bought new wheels that did accomplished the same thing without the issues spacers can create, especially cheap ones that are not machined perfectly for your hub diameter.
Sorry about the confusion. It's a Friday after all![]()
I ordered 1" Boras and I sort of wish that I had ordered 1.5. This looks very good.I added 1.5" BORA wheel spacers to my non squashed BL. Just added 35" tires. Love the wide stance, tire poke b/c of the standard flares.![]()
Pics with the 1” spacers?I ordered 1" Boras and I sort of wish that I had ordered 1.5. This looks very good.
What is the width on those tires?
Bronco is being built next Thursday. I've only ordered them so far.Pics with the 1” spacers?
But you have 37 right? I’m keeping the stock on my badsas, just wanted the tires to have wider stance and minimal poke.I ride on 1/4in spacers but also have tried 1in spacers see post 61-65 in my thread.
https://www.bronco6g.com/forum/threads/37x12-5r17-km3s-sasquatch-badlands-no-lift.26479/page-5
Yes, But I'm not sure how that matters poke is poke.But you have 37 right? I’m keeping the stock on my badsas, just wanted the tires to have wider stance and minimal poke.
Costs less if you buy direct form the manufacturer. AluminumSorry for the newbie question - which exact part is it? BORA 6 lug (plastic?) spacers?
those are 315/70/17 Falken Wildpeak at3wI ordered 1" Boras and I sort of wish that I had ordered 1.5. This looks very good.
Is the rear back up super bright or does the camera adjust? I love that bumper, I wonder if I could do duel yellow on aux and duel white on top hooking that to the backup factory rear lights. I like Baja design, do you think I could put these one on top of the other (that looks like a 4 pod design).I went with 1" Bora spacer. Have used them before very durable.
BORA TRUCK SPACERS
Bulletproof Off Road Adapters (BORA) are manufactured BY US (no middleman), right here in the USA! We use top-of-the-line, state-of-the-art, HAAS CNC machines, and only the best U.S. Alcoa 6061t6 billet aluminum. Unlike our competitors, we provide a LIFETIME WARRANTY.
https://www.motorsport-tech.com/index.html
Would be a tight fit?Is the rear back up super bright or does the camera adjust? I love that bumper, I wonder if I could do duel yellow on aux and duel white on top hooking that to the backup factory rear lights. I like Baja design, do you think I could put these one on top of the other (that looks like a 4 pod design).
Is that just a void space behind the light or is there a bracket, or did it come with the bumperWould be a tight fit?
The space behind the light is wide open.Is that just a void space behind the light or is there a bracket, or did it come with the bumper
