Spare Tire Dismount/Mount Tips?
JHawk
Ray
Heartland, USA
Fusion Sport
Do any of you veteran offroaders have any tips, techniques, or tools on the best way to remove the spare tire and then remount it?
I am trying to plan for the flat tire I will encounter some day and hoping to avoid a hernia
2Jeeps&PatriotX1
Denver, CO
35” or larger MT tires are a PITA. Have them on my jeep and truck. Jeep spare is definitely higher up. Sorry I cant help.
JHawk
JHawk
Ray
Heartland, USA
Fusion Sport
Thanks anyway. I see it as the cost to join the club. I did read the advice thread and took note of always take friends.
Toccoa
Isuzu Rodeo Sport
Having the backup camera sticking out so far on the spare tire carrier is going to help with getting it on. Traditionally, the hangers were stubbier and with a tire in hand, you were a bit blind when trying to line up the hole. Getting them off the hanger is pretty easy. Gravity does most of the work.
Tip for heavy tire/slash lack of arm strength: If you can lift the tire high enough to set the inner rim on the hanger, you can rest for a second before you attempt to lift it a little higher to fit through the center hole.
Used2jeep
Massachuvian
2007 Crown Vic P71
Sure hope that camera is sturdy.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
Don't skip leg day and doing some dead lifts will help, too.
BlueOvalBandit
Kenneth
Anaheim, CA
Tacoma
Pro tip for avoiding a hernia: make your kid do it while you sit back, supervise, and shout words of encouragement... Learned that from the old man
But seriously as other's said strengthen your legs and learn good lifting technique.
But the better technique is don't lift alone.
HankG13
Hank
Phoenix, AZ
2019 Ram 1500, 2017 Subaru WRX, 1990 Mustang LX
Practice in the driveway a couple times before you go out!
Used2jeep
Massachuvian
2007 Crown Vic P71
"Yeah Jack? I won't be able to go riding tomorrow. I threw out my back practicing changing my spare tire."
Bison
Matt
Fj cruiser, Power wagon
Ride with friends who have the same vehicle and tire size. Don’t carry a spare and just use theirs.
bead locks, tire patches, plugs , and a co2 tank will help, so hopefully you can fix it and not change it. Only had to pop the spare one time. My Fj came with metal valve stems that had no give in the rocks. Took about 10 seconds for it to be completely flat. Finished the trail and next day got new wheels with rubber valve stems. Haven’t had A problem since.
PSUTE
Western Maryland
Sierra
Yeah, plan on gravity helping me get it off. I'll be letting the tire guy get it back on...
Frank N
Frank
NJ and Outerbanks
2018 Ford Raptor
If you are alone, lift in stages. Get the cooler out or whatever in your truck to split the lift.
If you are not alone, they help....or they walk home, their choice.
BEM-S4
Philadelphia
BMWs & Porsches
Dumb question - maybe... I've never owned a vehicle with a spare on the back before. Is it just secured with lugs like the other wheels? If the answer is "yes" something like this could help. Most of my cars have stud sets installed but on those that don't I keep one of these in the trunk, really helps aligning the wheel when doing a regular mount / dismount. I can't imagine the spare would be any different.
https://www.ecstuning.com/b-schwaben-parts/wheel-hanger-m14x15-thread/002840sch01a/
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Exactly what they said...
If on the trails and you needed to use the spare, just throw the flat in the cargo area. If you have no room, it means you have gear you can use..a cooler, a tool box to at least elevate it a foot or so off the ground. If not use the spare (before mounting) to elevate old tire. If you forgot and already mounted the spare, use the Jack to elevate the old tire. You can also carry a block of wood with you at all times. If you really don’t want to deal with all that...carry 3 cans of fix a flat ( for 35s), 2 for (33s) and not use the spare..Lots of ways...just gotta get creative.
At home, i use a metal folding chair as elevation..yes you will need to take the spare off at home at some point..to work on wiring or just to rotate the tire so the sun won’t fade just one side of the tire. No i don’t like tire covers, I’d rather rotate it lol.
