- Banned
I know of 3 Broncos where their speedometers are off by ~2mph. Have you seen anything like this?
the factory tires read two miles slower at 40...the speed o says 40 but the broncos are going 38..Did you put on larger tires? The computer is probably thinking the factory tires are still on. You have to tell the computer your new tire radius.
ICK. This is really about bragging, not speedometers.My bronco's (3 of them) seem to be off by 2 miles an hour slower.Anyone else have that problem
i already took one to the dealer and they fixed it...What are you using to the difference, perhaps its off since you have 3 of 3.
If you know how to fix it, then what was the purpose of this thread other than rubbing salt in the wound of other forum members who have three less Broncos than you?i already took one to the dealer and they fixed it...
letting other know.Isnt this a forum to let people know things..If mine are all wrong I cant be the only one with this problem.Also if you put larger tires on it.You would need to have it cal·bratedIf you know how to fix it, then what was the purpose of this thread other than rubbing salt in the wound of other forum members who have three less Broncos than you?
If that was truly your intent, fine. But the fact that you had to mention you had three and then say you also will be getting a Raptor, etc (that post seems to be deleted) makes it look like you wanted to brag. And that's why folks are calling you on it.letting other know.Isnt this a forum to let people know things..If mine are all wrong I cant be the only one with this problem.Also if you put larger tires on it.You would need to have it cal·brated
I changed it .You are right does sound bad .Thanks for the tip..If that was truly your intent, fine. But the fact that you had to mention you had three and then say you also will be getting a Raptor, etc (that post seems to be deleted) makes it look like you wanted to brag. And that's why folks are calling you on it.
Which sounds more douchebaggy:
A) I know of 3 Broncos where their speedometers are off by ~2mph. Have you seen anything like this?
OR
B) your post
