BigMeatsBronco
Allan
2021 FE 2 door
I like the standard U joint at one end. Standard U joints can be replaced as opposed to the entire drive shaft. Why not at the other end- it still must be a CV joint? Why didn't' the Bronco come with standard replaceable U joints to begin with?
Because the CV joints
Offer a true constant velocity. This means less vibration than u joints. They are superior for a drive line that is spinning at high speed with low gearing
SierraBronco
Does anyone else get mesmerized by the velocity changes created by an angled u-joint? Just me?
Ford Bronco Spicer Driveshaft initial impression and long term review. IMG_2023
Fordified1
Bob
Mid South Texas
ā€˜15 Mustang ecoboost, 4wd Excursion, ā€˜69 Mach 1
To add to BigMeats’ response. They also require the angle to be near exactly the same on both ends or they vibrate. And they have to be assembled ā€œtimedā€ or they vibrate. Packaging is easier if there’s leeway with angles. I believe CV’s also can move in and out slightly where u-joints are absolutely fixed length (correct me if I’m wrong in this).
