rtsherry73
Richard
Boynton Beach, Florida
Toyota
Wow! Look at that ground clearance! You could run over your mean neighbor, and you wouldn't even know it... and He wouldn't even feel it.
rtsherry73
Richard
Toyota
New Front-End Camo A Direct Match With F-150 Raptor Prototypes
The heavy plastic panels that have covered the front-fascia of past Bronco Warthog prototypes are now gone, replaced by nothing but graphic wrap and a mesh-covered grille. An important detail is highly suggested with the new camouflage—a Raptor-style FORD grille treatment. The strip of graphic camouflage visible behind the grille has two important cut-outs that are a perfect match with what was seen on F-150 Raptor prototypes. The camo cut-outs are for the open spaces created by the “R” and “D” on its iconic FORD-emblazoned grille. This is our most suggestive clue that the Bronco Warthog’s grille will share the Ford branding of its beloved F-150 Raptor stablemate.
Signs of Government-Mandated Marker Lights
The Warthog’s new camouflage also shows signs that it will get government-mandated marker lights, like the F-150 Raptor. The shin strip of camouflage at the top-center of the grille opening is the likely spot for the marker lights, just where the strip of graphic wrap is placed.
Bronco Warthog’s Front Bumper Revealed
We also get our first look at the Bronco Warthog’s front bumper, in a more uncovered state, for the first time. We get our best look at the prominent skid plate, and our best feel for the its interplay with the Warthog’s flared fenders.
New Signs Of Flared Bodywork
This latest Bronco Warthog prototype appears to be less-disguised underneath the vinyl camo, giving us our best look yet at the chiseled nature of the widebody Warthog’s flared sheetmetal. We also see what looks like the final shape of the plastic fender flares, which appear to take on a more angular shaped due to the altered body work.
Side Running Boards Make A First Appearance
This Bronco Warthog prototype is equipped with side step rails, or running boards, for the first time. We can see the low-profile nature of the running boards, that appear to have been designed so as not to adversely affect ground clearance. All prior Warthog prototypes had no signs of step rails, of any kind.
Bead-Lock Wheels and 37s!
This Bronco Warthog prototype is thoroughly kitted-out, with bead-lock wheels, while riding on the promised 37-inch tires.
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-22.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-1.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-2.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-3.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-4.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-5.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-6.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-7.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-8.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-9.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-10.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-11.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-12.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-13.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-14.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-15.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-16.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-17.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-18.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-19.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-20.jpg
warthog-bronco-ford-grille-marker-lights-running-boards-side-steps-bead-lock-37-inch-wheels-21.jpg
Sorry if this has been discussed: Can we presume all Warthogs will be 4 doors and Hardtop?
Ponyride302
Central Virginia
04 F-350 CC dually, 97 Infiniti QX4, 21 Bronco BD
Kind of like those steps attached to the rock rails...
That is what I was looking at too. I want steps, but was not sure how that would work with the rock rails on the BD I am ordering. They also look fairly inconspicuous.
shdwblckRS
Talbot
Denver
2013 Jeep Wrangler 2 door on 40's, 2017 Focus RS
The rear axle is different then the normal bronco.
Is it just a different cover over the differential or is the entire axle a more heavy duty model?
https://www.bronco6g.com/forum/atta...steps-bead-lock-37-inch-wheels-19-jpg.123602/
That was the first thing I noticed as well. TBH I think it's just a different diff cover and not an upgraded axle. The bolt pattern of the cover looks the same as the regular Bronco and isn't similar to what's on the F150's or the Raptors.
fschael
Federico
Houston, Tx
2002 F-150 Supercrew FX4
Do you see a single "Ford" emblem on the exterior of the Bronco? Many dealers are currently building separate showrooms for Broncos only.
Yes, on th rear on the left side you will find the only one. Dealers are doing it because they want to and they see an opportunity for after market accesories. However, it's true that they are building the Brand but is not going to be a separate brand. It's going to be a sub-brand.
John Bronco_ I am here
North America
johnbronco.com
'66 Bronco, '21 Bronco
All I got to add is this proves it takes 37's to make the 4 door look right; proportions man, it's all about proportions. I heard on the interwebs that "40s are the new 35s" but, call me old fashion, I still like 37s.
Warthog
Rick
MN
JJZ109
Arizona Territory
GT350
do you have a link or a pic?
If you are correct that the part is already published ... then this would lead me to think the Warthog will be coming soon and NOT in 2023.
Sorry, no link or pic... The base part number is obscured in the illustration and there is no price info on it, but it does seem strange for it to be listed in the 2021 catalog.
RRaptor
Rick
2019 Raptor
New Raptor starts about $64k, runs up to a little over $80k with ALL the bells and whistles including 37” tires. Warthog might start out below $60 and run over $70k loaded. Of course they will be a hot ticket so ADM might be added on initially.
Rollerstud98
Christian
Airdrie
2015 Nissan Titan
Love the look of the exhaust poking out there!
Advertisement
BuiltRight
Advertisement
