Sport Mode - Is over-the-air update to add it possible?
Gamecock
  • Thread starter
  • Banned
  • #1
The CNET review pasted below mentions that: "Inexplicably, however, this model does without a Sport mode. (Over-the-air update, anyone?)"...and of course the lack of a Sport mode in Badlands/FE has been baffling from the beginning. Does anyone have a feel for whether it could be added with a software update, either from Ford or by a dealer/Forscan?
https://www.cnet.com/roadshow/reviews/2021-ford-bronco-review-preview/
iamchewby
Chewby
Interesting question. If the Sync 4 has the ability to re-map the ECU it could happen. Sync 4 is connected to pretty much everything on the vehicle so it maybe can. Possible? Yeah. Probable? Not likely.
Berwolf
VW GTI
I don't think so. I don't think it made it because they are limited in the number of drive modes they can have so they had to choose. Just a theory.
Beach_Bum
Ken
St. Augustine, FL
While they are limited in the number of GOAT modes, I believe that via Forscan Sport can be enabled and another (Eco?) can be disabled getting around the limit. It wouldn't be an official Ford update.
Gamecock
Gamecock
  • Thread starter
  • Banned
  • #5
I pray that’s doable…
gizmohd
Darren
Bronco Sport (Wife), Bronco Badlands (Sasquatch)
Isnt the only difference between the Sport Mode and Baja mode 2wd vs 4H? I was looking at the modes it was setting and it seems as much...
Silver-Bolt
Bill
Portland, OR & Eureka, MT
2018 Ford Raptor, 2020 Audi SQ5, 2023 Wildtrak
Nope. Search as it has been covered many times.
Natai
Sean
Sacramento
Nissan Sentra, Mercedes GLC
Any idea what the limiting factor is?
Appears to essentially be a software setting. The only thing I've seen that could maybe be a challenge is fitting all of the mode icons on the instrument cluster menu at the same time, and that seems like a stupid reason to leave a mode off of the top-level trims.
Beach_Bum
Ken
St. Augustine, FL
I think the dial (maybe someone who has cycled through the modes at the Roadeo can confirm), but I don't think it continuously spins to the next GOAT mode. I think it stops on the ECO mode. AFAIK, you can't spin it one mode further to engage Rock Crawl. You would have to spin it to the opposite spectrum in the opposite direction on the GOAT dial. So if that behavior holds true, there are only so many GOAT mode stops on the dial.
With regards to the software settings, all modes should be preset and present. But are only available to specific trims. It should only be a matter of time for someone familiar with ForScan to map the variables and settings. Of course, with systems so integrated, that someone will be taking on the risk of opening Pandora's Box.
Rick Astley
Up Doug's ass
d
Bingo. These won't be OTA updates/changes.
Forescan will be the ticket here. It's a difficult tool and not nearly as intuitive as it seems. Likley there's a limitation to the number of modes available at a given time, locked by trim level, plus dealers having access to the entries/changes.
We disable the start/stop on our Ranger, plus a few personalization's to the driving modes but revert and reset the ECU anytime it has to go in for service.
Raptor911
Raptor911
Broadlands, VA
No way Ford would allow goat modes to be downloaded. Ford does not make $$ from this. They want you to pick the trim that has the modes you need.
Beach_Bum
Ken
St. Augustine, FL
And I didn't mention it, but I'm glad you did. Any system changes can be ascertained by the dealer. With systems so integrated, one setting can impact another. Not a big deal with regards to ASS. But not reverting the settings changed may be reason that a dealer needs to void a warranty claim.
Natai
Sean
Sacramento
I don't think the physical dial has an actual stop one way or another (can someone that's already got theirs verify?), especially since not all trims have the same number of modes. You may be correct that you can roll through all the modes and then 'wrap around' but that's still just a software/UI thing.
At this point, I'm betting they just can't fit an extra icon in the UI without making them smaller (which makes coding the UI a LOT more complicated). That and they evidently didn't want a trim that has all the modes.
If it was that simple, then Ford would have offered a trim with all the modes - or better yet, included a paid option to unlock additional modes regardless of trim.
Brad Fx
U.S.A
Jeep Commander
I think it’s like a View-Master reel; you’d have to change it out to see difference pictures.
Ford Bronco Sport Mode - Is over-the-air update to add it possible? 4100A361-A6E5-47A5-AAB4-F96ECCBE00D1
Bronco4lyfe85
William
2019 Challenger Scat Pack
No way it’s an OTA. When we ordered my wife’s badlands I was disappointed to find out it didn’t include a sport mode. I drove a 2.3L big bend Sasquatch and it felt great in sport mode so I’m guaranteeing it makes a difference.
