- Paul
- Sep 17, 2021
- 7
- 1,190
- 3,544
- Carmel, CA
- F250 Powerstroke, Grand Cherokee
- Wildtrak
I haven’t seen anything mentioned lately about that Sprint Booster that some guy was selling on here. It’s basically a pedal commander type thing, has 18 different throttle lag settings, a valet mode, and an anti-theft setting. Anyway, I know several people purchased them, I was wondering if anybody else has had issues with it.
I had mine on for about 1500 miles with no issues. It actually made a very noticeable difference and I was very happy with it. Then all of the sudden, I started getting all kinds of dash warnings. Powertrain malfunction was the main one. When I took it to the service dept, they thought they needed to replace the whole pedal assembly. After that, I knew what it was. I told them that I had installed the sprint booster and to remove it and see if that helps. They did, and it seems to have solved the problem.
So if you have one installed, and you’re getting several codes popping up and can’t figure out what it is, try removing the sprint booster. If you haven’t had any warnings yet, that’s one thing to check if you ever do. Other people have mentioned the same codes popping up that I had, and their service techs couldn’t always find an answer. If you were thinking about getting one of these, maybe get a pedal commander instead.
