- Matthew
- Dec 14, 2021
- 8
- 127
- 443
- Sarasota, FL
- Website
- www.srqfabrications.com
- 2021 Bronco 2Dr
- Wildtrak
Know you are going to be wheeling hard with your new Bronco? Don't settle for body-mounted rock sliders. These rock sliders mount directly to the frame and are designed to take a beating!
With 3 legs reaching to the frame per side on the 2 door model and 4 legs on the 4 door model, you can count on these sliders not moving! These sliders can either be welded to the frame or bolted to the frame utilizing up to 6 bolts per leg. All hardware is included for those wishing to bolt-on these sliders but drilling will be required on your part.
About these sliders:
Lead time: 15 Weeks This is only an estimate and may occasionally be slightly longer or shorter depending on the workload and availability of parts. This does not include time in transit after shipment
- Main Tube: 2x2" Square 3/16" Thick Steel Tubing
- Frame Tie In Tubing: 2x2" Square 3/16" Thick Steel Tubing
- Frame Plates & Gussets: 1/4" Steel
- Round Tubing: 1.75" .120 Wall HREW Steel Tubing
- Top Plate: 11 ga Steel w/ Dimple Die
- 2 Door: $649.95 Raw Steel, $949.95 Satin Black Powdercoat
- 4 Door: $749.95 Raw Steel, $1049.95 Satin Black Powdercoat
