- Thread starter
- #1
I've searched around a little, but I'm still insecure enough to ask here. LOL! I'm sure you guys get tired of answering the same questions over and over. I have two sets of Diode Dynamics SS3 lights -- yellow for front and white for rear. My Bronco has the factory auxiliary switches. When I ordered these lights, I also purchased two harnesses. Now I'm thinking that I probably didn't need them, and if I don't, I need to return them before my time to do so expires. Do I need the Diode Dynamics wiring harnesses if I have factory switches?
My uneducated guess is that since the factory auxiliary switches contain fuses and relays, all I need is the Deutsch-style pigtails that were packaged with the lights and simply connect the light's red wire to the correct switch wire and ground the black wire. Correct?
Thanks!
https://www.diodedynamics.com/heavy-duty-dual-output-offroad-wiring-harness.html
https://www.diodedynamics.com/light-duty-dual-output-offroad-wiring-harness.html
No sense in using these harnesses if they will just be redundant with what my Bronco is already equipped with.
Thanks!
