Start-stop with Manual Trans.
jcaruso970
James
Telluride, CO
FJ Cruiser
Have had my Bronco a few weeks now - manual trans 2.3L BD Bronco. I notice that when sitting still in idle, when I put in neutral and take my foot off the clutch it stops. Also, when someone opens the door, it stops... Kinda annoying... How can I stop this...? I can't be the first to complain about this...
RAKET
Derick
www.raketdesigns.com
Thereā€™s a Forscan fix and (I believe) a harness option that disengages the start/stop feature. Iā€™ve gotten used to it, and usually use the ā€œoff buttonā€ when I jump in.
GToddC5
Todd
South Jersey
www.bronco6g.com
Press the button that disables it.
Mustbeheresomewhere
Micah
2012 Chevrolet Silverado, 2022 Bronco Badlands 4D
Yeah, if you have it in gear with the clutch engaged it will stay running. If you put it in neutral it will stop the engine until you press the clutch. I installed the auto stop eliminator and havenā€™t looked back.
mtap
Mervin
Cape Coral, FL
Toyota Tundra, Hummer H3, Harley Sportster
Once auto start/stop is off, you can let go of the clutch in neutral and it wonā€™t shut off. I never had the issue you described. Even with doors open. I start my bronco in the am, turn off auto start/ stop and exit vehicle with no issues. Why do i exit? I get the temp setting to what my daughter likes before i take her to school.
Also no need to install the harness or mess with Forscan ā€¦muscle memoryā€¦disengage e-brake, disengage auto start/stop and youā€™re good for your travelsā€¦
I also have a 2.3MT BD
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
I disabled mine w/forscan. Check, and double check the spreadsheet. If you modify the right line it works!
jcaruso970
jcaruso970
James
Telluride, CO
FJ Cruiser
Cool - I will do that - don't want to do any mods/fixes with Forscan if I can help it... I hate most of the electronic gadgets including the e-parking brake... prefer the old school manual hand brake...
mtap
Mervin
Cape Coral, FL
Iā€™m right there with you..i want visual confirmation that e-brake is engaged.
my dealer didnā€™t even know how to operate it and broke the latch to my e-brake. Just sayin.
mike8675309
Minnesota
I kinda like it. I save fuel at long lights that way. You can always press the button to cancel it if it stops when someone gets out.
BigHoof
PA
Ram 2500
If the vehicle shuts down with hot turbos, does the oil cook in them? Its not like the oil keeps circulating. The amount of fuel saved vs engine wear from restarting makes it a no brainer to disable the feature IMHO.
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
A.S.S. Plug.
I installed it the second day of ownership, worth every penny
JoeSpeed
Eatontown, Jersey
2dr 2.3 Manual
And youā€™re killing the starter as you allow it to turn off and on, all for a single Mpg
mike8675309
Minnesota
We shall see. Remember starters in vehicles with start/stop are not your past starters. They are fairly new designs of permanent magnet motors with higher temperatures and higher current capacity than past starters. Also starting a warm engine is much easier than starting a cold engine. If it meets the needs that Ford needs to warranty it, I think it is just fine. Again, we'll see.
Willub
Billy
Massachusetts
Not really an issue with modern turbos and oil. Also, oil may still circulate for a bit after the engine is off, because science.
