I have been having issues with my 2021 Badlands 2.7 starting. I'll try to explain best I can. I press on brake pedal and push the start button. Sometimes the brake pedal pushes back and the engine acts like its not going to start but does. Then I lose all the settings on my dash ie gages. I also have had issues with trying to remote start using the Ford App. It wouldn't start nor lock or unlock my doors. When I approached the vehicle to try it manually, it didn't recognize my hand on the handle. I tried to use the keypad and it didn't recognize it either. I had to use my key built into the fob. Once inside I noticed no power to anything. I sat there for about 5 minutes and I heard the "hmmm" that you hear every time you approach the vehicle with the fob on you. I pressed the pedal and it started but again all the dash settings had to be reset. I uninstalled the app and reinstalled and then it started working again. But today I got in and it did the brake pedal raise up and not wanting to start but did. HELP!!! Ford says "we can't duplicate it and it has not thrown any codes".
