Steering Rack Fix - BusterBrace now available
Status
Not open for further replies.
Keith Dunford
Keith
New Braunfels, Texas
www.texascompletebronco.com
2022 Bronco Wildtrak
As many of you know the steering on the Bronco has had its problems. We believe that after lifting your Bronco a proper alignment is critical in helping to stop the inner tierod from breaking. However for a piece of mind we have started carrying the “BusterBrace” from @Txbroncbuster. In the coming months we will have full replacement tie rods available however that still leaves the issue of the Rack failing. TxBroncBuster has solved that issue with the BroncBushing, inserting this bushing on the driver side of the rack helps take out some of the stress experienced while offroading and doesn’t allow the rack to separate from the pinion gear.
https://www.texascompletebronco.com/products/broncbushing?_pos=1&_sid=b64dfd27d&_ss=r
Ford Bronco Steering Rack Fix - BusterBrace now available 68276787-DA87-4195-9701-5CA65356C24B
Status
