88to21bronco
Tennessee
2017 Nissan Titan XD
I ordered the Bestop Bimini top literally two days ago through my dealer. They said yesterday it was backordered, then later that day IT ARRIVED! Below is installation/thoughts:
INSTALLATION:
The directions scared me because they only mentioned a hard top, despite the Accessories catalog saying it fit both. But with a little common sense it's not an issue.
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 1
In the instructions, this bracket goes on the current hardtop bracket. But, alas, the softop bracket is farther back and different in design. But there is a pre-threaded hole for the bolt in exactly the right place. Crisis averted.
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 2
Not sure if you can make it out, but I screwed the back straps to the outside of the speaker bolt. The instructions say to attach it on the inside, but I didn't like the fit. It seems to be designed to go the way I did it. Win for me!
END RESULT:
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 3
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 4
THOUGHTS:
I had expected it to be easier to take on/off. Apparently, at least one bracket will need to be loosened and a the back straps unlooped from the buckles. 5 minutes maybe?
The front clasps have to be undone and the front part of the Bimini buttoned to itself to shut the top. I'll let you know the ease of that...
UPDATE:
So a trip to town later...
There is a good bit more wind noise at 60 mph, but livable.
Hey, those plastic clips that weren't in the instructions... apparently they are used to keep the extra cord from flapping everywhere. Who knew?
Flapping of the shade is minimal. I wouldn't enjoy the interstate with it on I imagine. But the highway was ok.
It did a good job of cutting down on the sun. Overall did what I hoped in that regard.
UPDATE (2):
The clips went on easier than I thought. I used a key to pry open one half of the plastic clip and slide the other side of the strap in. Then clipped the strap to a tightened part.
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 20210716_132742-
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 20210716_132814-
Every strap has a clip to fasten it down. I think it will help flapping.
UPDATE (3):
Update:
I snapped the front to let down the top. A breeze except the snaps to hold it in place don't meet without undoing the front hooks, which in turn makes the front sag. But I just flipped it back without snapping and it's fine. Top goes down without a hitch and latches perfectly.
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 5
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 6
Ford Bronco SUCCESS:  First Installed Bronco Bestop Bimini Sun Shade - Pics, Installation Notes, Impressions 2021 Ford Bronco Installed Bestop Bimini Sun Shade 7
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Nice.
Any flapping or vibrating against the cage while driving? (I have to stick a small towel between my spiderwebshade and the b pillar crossbar on my Jeep.)
BroncoKong Jr.
Andrew
Looks great. Thanks for the writeup. Curious how easy it is to undo the front so you can open/close the soft top.
88to21bronco
88to21bronco
Tennessee
88to21bronco
88to21bronco
Tennessee
That looks great! Nice write up. Does the mesh top provide enough shade? Does it cut down on the wind for the backseat?
Also, any fitment issues with those 285/70s?
The tires fit great! Like they were meant for it. I have a 4wp level kit waiting on a friend to help install. I'll update.
88to21bronco
88to21bronco
Tennessee
88to21bronco
88to21bronco
Tennessee
Toccoa
Isuzu Rodeo Sport
Thanks for sharing. Seems like removing the soft-top would really make this option pop.
Cbiggs
Cory
West Chester PA, OCNJ
85 CJ, 94 YJ, 04 JK, 17 Taco
Great write up and subsequent responses! This was a must have accessory for me, and it looks to be about what I expected but this post puts the mind at ease. Nice rig, good luck and thanks 🙏.
Ripcurl
DodgeRam 1500 Laramie, HarleyDavidson 48
Sounds like you overrode the directions a couple times, do you think the design isn't quite there yet or was it the possible hard/soft top thing you mention?
How was the upward view from underneath? Enough for passenger sight-seeing in the appropriate geography/landscape? We have some nice vertical views out here going through the Rockies.
Dads_bronze_bronco
Definitely made for top down driving on the beach, around the beach town, on curved roads with views in the mountains, etc. 50 and below driving. But so is a soft top really. (Sunrider fold-back is doable at speed for short periods I guess.)
RhodeIslandRed
Northeast
www.bronco6g.com
TD5 Defenders
Your grass looks great. Someone had to say it.
Sorry you took it that way. The side shot with the trees in the background look like a grove.
