Superlite 50 hard shell RTT (roof top tent)
SD Bronco
Weston
Ford F-150
The static rating for the roof is 450lbs. Still not a lot to work with.
Very true. 340 lbs for two people is really cutting it close. I guess the something like the Rhino Backbone system is the only non external cage option that I know of to add strength(?). Since the Superlite is so light I was hoping to be able to take it and the rack system off when not in use
wilbersk
Sean
2023 Bronco Raptor
I’m still confused on the rhino rack backbone because it has disclaimers all over it that you are still limited by factory load ratings.
SD Bronco
Weston
Ford F-150
Is it about the factory roof load rating or gvwr?
Username_not_found
Minnesota
Fiat 500 Abarth
Good motivation for my wife and I to not put on weight. 290lbs between the two of us.
AcesandEights
Ace!
Oregon
DR650
I think you need to add the mattress and ladder too.
2ndgenirish
William
Ford Edge Sport
FWIW, I chatted with Thomas Rhines at GFC about perhaps attaching a RTT directly to a Bronco without a roof rack. Here is the reply:
"Thanks for shooting us a message in the chat! Most roof top tents will require a roof rack to mount the tent to. Our roof top tent can mount using several different mounting solutions, but for the Bronco especially, you will need a roof rack to put anything on top of it."
I have not given up on a direct attachment, using the factory attach points. Maybe someone and cobble something up.
Ramble_Offroad
Nels
Northern CO
2014 2D JK on 35’s
Not sure if this has been discussed, but if your keen on seeing what the GFC Superlite RTT looks like on a 2Door check out “Justin B. McBride” on YouTube.
