SAME!I agree. I don’t mind slightly less rake but still want a little bit for the same reasons.
Do you folks know if the STOCK BADLANDS (not Sasquatch) is the same Bilstein shock as Sasquatch, because it IS A BILSTEIN, but NOT a sasquatch??@Badassbronco & @JRock17 It’s hard to give exact numbers as there are a lot of things that affect it such as: trim level, engine size, doors, vehicle carrying weight, additional mods and spring settlement over time. Almost all our installs are about 2.25” of lift, and thats what others have reported back to us after settling and alignments. The rear gets a slight bias usually about 1/8" or level depending on the factors before.
You'll like the way these look thenSAME!
Similar but slightly different, specifically in length. If you order the Bilstien version of our spacers you'll be goodDo you folks know if the STOCK BADLANDS (not Sasquatch) is the same Bilstein shock as Sasquatch, because it IS A BILSTEIN, but NOT a sasquatch??
Thanks for posting, very good info to know. I was looking for about that height but still need that factory rake. I installed my 37’s this weekend and they look a bit stuffed without a little height. Waiting on the SVC’s to ship, how long did it take you to receive them?Hi guys I installed the SVC collars this weekend on my 22 Wildtrak. I gained 1.75” on the front and back, so I have the factory 1” rake. As far as CV angels stock on drivers side was 6 degrees and passenger side was 5 degrees. After the install drivers side is 12.5 degrees and the passenger side is 11.9 degrees. I also dropped the LCA and it was a lot less work.
Thanks for the info. Is 12.5 degrees a bad thing?Hi guys I installed the SVC collars this weekend on my 22 Wildtrak. I gained 1.75” on the front and back, so I have the factory 1” rake. As far as CV angels stock on drivers side was 6 degrees and passenger side was 5 degrees. After the install drivers side is 12.5 degrees and the passenger side is 11.9 degrees. I also dropped the LCA and it was a lot less work.
Are you in the process yet of making a coil spacer lift for the HOSS 3.0 Fox shocks?Feel free to give us a call at 888-976-5588. Happy to help get you in a set
Rides just a little stiffer but nothing bad, the 12.5 degrees I’m not sure I would think it’s ok, I’ll have to check into it more.Thanks for the info. Is 12.5 degrees a bad thing?
How’s the ride?
I got them in a week.Thanks for posting, very good info to know. I was looking for about that height but still need that factory rake. I installed my 37’s this weekend and they look a bit stuffed without a little height. Waiting on the SVC’s to ship, how long did it take you to receive them?
And I live in Michigan.I got them in a week.
Seems about right.@SVCOFFROAD Any idea what the install time would be for an 4X4 shop to do this? I'm getting quoted 6-8 hrs...seems high to me.
Also, I assume there's no issues with the MY22 w/rear swaybar?
It also took me about 7 or 8 hours alone in my garage. With a lift and maybe better tools I could see at leat an hour getting knocked off.@SVCOFFROAD Any idea what the install time would be for an 4X4 shop to do this? I'm getting quoted 6-8 hrs...seems high to me.
