- Feb 21, 2020
- 112
- 7,301
- 25,622
- North Texas
- SUV
- Undecided
Instead of looking for information about the the Bronco on the 4Runner forum you could also try looking for information about the Bronco on the Bronco Forum.Found this message on a 4-Runner forum. And yes, it is just some opinion on the interwebs, but I thought I'd see what you guys have to say. Essentially the argument is that on an IFS system, only the tire under compression will have traction since the other tire will have near-zero weight load. Also, since articulation on an IFS is mostly limited by the shaft angles and geometry more than the sway bar, the increase in articulation will be minimal at best. Thoughts?
From Sonoran Steel FAQ:
Sway bar disconnects are not needed with an IFS suspension
By disconnecting the front sway bar you may gain a very slight amount of added a-arm droop, but here is the problem with an IFS truck. The only tire that has any weight on it is the one compressed, so it does not matter if the other tire is in the air, almost on the ground or on the ground. It will spin because it has no weight on it.
It is however correct to disconnect a sway bar on a straight axle truck as it will increase articulation. The real benefit of having a straight axle is that both front tires bear the weight at all times, not only one like an IFS truck under articulation.
We do not recommend sway bar disconnects as we have found them to be completely useless on this vehicle.
From your 4Runner article: " We do not recommend sway bar disconnects as we have found them to be completely useless on this {4Runner} vehicle."
Meaning, on the 4Runner, it is NOT an evaluation about the SBD on the Bronco.
Bronco Badlands Stabilizer Bar Disconnect In Action!
I made a GIF out of this clip from the Youtube Reveal. Pretty sweet that it can do it under load!
