Sway Bar disconnect option (aftermarket or factory) for Wildtrak?
damarble
Spokane
01 Sport Trac
Gotcha. So you have to crawl under the vehicle. Still, who cares for $80.
I knew $100 wasn't getting you the electronic version that can be disconnected under load.
4 wheeling often requires a lot of crawling under the rig. Not a good hobby if you don't like getting dirty.
Austin26
Austin
Houston, Texas
2019 Subaru Crosstrek
I'm new to off-road modifying. Are we talking about the same kind of anti-sway bar that I'd take off the front of my 2000 Mustang at the drag strip? I could take mine off and put it back on in probably 5-10 minutes, and it definitely wasn't meant to ever be removed.
SHLYGRR
Nick
Hyundai Elantra GT Sport
the badsquatch costs substantially more
I don’t know the budget that OP is working with, but if you’re open to paying for a sway bar disconnect on a Wildtrak (which won’t be cheap), I don’t think getting an upgraded Badlands is a big deal. You’re already playing around in the upper cost range of the Bronco trims. Why not throw down a little extra to get what you want?
Additionally, based on the pricing breakdowns posted on this forum, a fully spec’d out Badlands Sasquatch is maximally $4k more than a Wildtrak. Not sure if I’d call that “substantially more”. It’s less than 10% of the cost of the vehicle.
MSF
Mohammed
Ontario
No car
I was under the impression the sasquatch package costs 10k, but yet again, you're right, $4k aint that much to add to get all that extra specs. cant wait to play around with the B&P
Megawatt
JO
Where the asphalt melts in the Summer
JKU on 35’s and 2.5” lift. A misplaced Texan
Anyone who tells you the disco is only for rock crawling does not understand what a disco is, what it does or what the benefit of being able to disco is. If you never rock crawl you can still find the absolute benefit of disco once you get off road.
Easy answer is if you can get any off road vehicle with sway bar disconnect then do it. Because having the option to disco is something you will learn that you will use often off road. The bronco unit is hydraulic and that is a huge step up from the Jeep Rubicon electric unit in many ways that I don’t even want to get in to.
BroncoKong Jr.
Not a Bronco ... yet
Pricing survey had Sasquatch as $2500 on Badlands, half the cost of getting it on other trims.
  • Like
Reactions: MSF
ekim
NJ
Jeep TJ, Ford Excursion
Sway bar disconnects aren't the only solution to good off-road articulation. I have a Currie Anti-Rock on my Jeep and the rig is very stable and predictable on trails with somewhat more lean when turning on the road.
RG7
B8 A4
Hydraulic SBD is a convenience feature, not an added functionality. On non-badlands Broncos, you’ll be able to disconnect the swaybar for free with a ratchet and a wrench.
If you know you’ll be disconnecting your sway bar all the time it’s really nice to have— but again it’s not a feature you’ll be losing if you don’t get it, it’s a convenience and a time-saver.
Megawatt
JO
Hydraulic SBD is a convenience feature, not an added functionality. On non-badlands Broncos, you’ll be able to disconnect the swaybar for free with a ratchet and a wrench.....
Do you know where the sway bar is on the Bronco? On a Jeep it is the furthest bar on the front of the vehicle. Very easy to get to (I manually disco often). On the Bronco looking at pics it looks like it is not in the same location. So to say you will be able to do so manually On the Bronco could be a stretch.
Megawatt
JO
Currie anything rocks!
RG7
B8 A4
I’ve seen pics of the underside where the bar mounts, but haven’t gotten a good look at where it connects to the end links. You’re right I shouldn’t assume it’ll be easy to get to but I can’t imagine a 4x4 will be difficult to access the end links.
Megawatt
JO
Yeah it looks like it is behind the front wheel is only reason why I’m asking.
Appears like the front driveshaft (that is not there) is above and to The left Making the pic of hydraulic disconnect behind the front wheel or under the drivers feet?
Same vehicle view from front.
Advertisement
Advertisement
