Switching out Sasquatch M/Ts with A/Ts?
BeerForMyHorses
Jared
Ford Fusion
Not a gearhead, just an enthusiast, so my bad if this is a dumb question, or has already been discussed ad nauseum (I'm sure it has, but search function didn't pull up what I was looking for).
Anybody opting for the Sasquatch package, but thinking about swapping out the 35" mud tires for 33" all terrains? Looking at the KO2's. Will anything need to be re-geared? Speedometer be off?
I'm thinking this will be a better way of keeping it as my daily driver, as well as the occasional overlanding trips to places like Moab or the Rubicon. I should be able to sell or trade those 35's pretty easily, right? Any other thoughts?
And I am looking at the Badlands, but might go basemansquatch to save money.
Thanks in advance.
Advertisement
Chrism81
chris
connecticut
Mazda
I was thinking of doing that too but wondered how the gear ratio with the sasquach would be affected by putting on smaller tires. I don't want it in the zone where the turbo keeps spooling up. Maybe with the 10 speed auto that won't be a problem
kodiakisland
Arkansas
2012 Tacoma, 2016 Camaro, 2018 Indian
Thanks in advance.
No regear needed. Speedo may be slightly off, but for me it won't be a concern. I imagine I will go with 285/75/17s after I wear the original tires down, which won't be a huge difference for the speedo.
BeerForMyHorses
BeerForMyHorses
Jared
Ford Fusion
  • Thread starter
  • Thread Starter
  • #4
Manual transmission is on my must have list. Any thoughts on that?
SpecOpsHippie
Al
Manitou Springs, Co
GMC Denali 2500HD, Audi Q5, Triumph Bonneville
So your high hear on the interstate or anywhere your driving around 70, will produce higher RPM and subsequently worse gas mileage. If youre doing stop and go it may help with smaller tires because of reduced rotational weight.
I think computed for the 35 inch tires and the high gear in the 10sp gives you 2019rpm.
I’m going to see how the M/T does in the snow and the trails here in Colorado before I switch them out. I was never happy with the compound of the KO2 in snow and on rocks. Little better with Duratracs. There tires better than both of those for snow and rocks but they don’t last.
CoolTech
Kendall
Santa Clarita, CA
Touareg TDI
You can easily do this swap without consequence. Although you will pick up a couple hundred rpm on freeway driving - but your gas mileage will IMPROVE. The lower ride height and aero benefits will easily trump the couple hundred extra rpm.
Fly by Nite
Walt
Pa
Going from 35's to 33's is a 5.7% difference.
At a real 70 mph, speedo will read 74, not a huge difference.
5.7% increase of 2200 rpm is 2325 rpm, not a huge difference.
The extra $5k for the Squatch is a huge difference for a dd!
BeerForMyHorses
BeerForMyHorses
Jared
Ford Fusion
  • Thread starter
  • Thread Starter
  • #10
Haha fair enough. In the current phase of life I'm in, it'll be a DD.
That said, the off-road goodies in the sasquatch package WILL be used
Rivers90
Ben
california
xterra mx5
The Badlands comes with the same gear ratio as a Sasquatch and it has 33's.
So by putting 33s on your Sasquatch you turned it into a badlands. It has the same locking differentials as the Badlands, the same gear ratio as the Badlands and the same upgraded suspension as the Badlands.
it's not a full Badlands because it doesn't have the sway bar disconnect or all the goat modes. But it is a less expensive way to get almost a badlands.
jayhawkco
Aurora, CO
2006 Nissan Xterra Off Road
Question, as I've never done it before. Is it possible to "upgrade" tires at time of purchase from a dealership? I probably won't feel like dropping a grand on tires right after I buy this nor do I want to deal with trying to sell tires after the fact.
Advertisement
Advertisement
