- Kraig
- Jun 2, 2021
- 32
- 872
- 1,610
- US - Alabama
- 2014 F150, 2014 Focus, 1973 Bronco
- Wildtrak
Nice work!
Thanks for documenting all the work you've put into this and sharing with us!I should have taken more pictures of the radio install to show the mic locations and antenna stuff which I'll get soon, for now I have some photos of the compressor install. I want to be able to use it without messing with the hood so I routed a hydraulic hose to the compressor fitting and a custom stainless bracket on the front crash bar mount. The bracket is shaped so that it blocks some of the mud that the top of the tire can sling forward in that area.
Outstanding work! I posted this on a Mestastic Signal group consisting mostly of hams that aren't afraid to replicate what you've done.the LoRa radio / Meshtastic node is in the car now. I also added a pair of charge ports to use but unlike stock, they are wired to my big auxiliary battery and are always on for charging overnight with the car off. The button on the right is connected to a digital timer module that activates my compressor for 10 minutes and then turns itself off. The stock USB ports is tucked in the back and directly connected to a Carlinkit Android module and my Mobilinkd packet radio modem. Those 2 items shut down with the car but the modem has an internal battery so I have the option of manually switching it on if desired. The Carlinkit is only useful with the infotainment on.
