1994 ford bronco xlt..OK..So I got tired of messing with the rear window problems. Here’s what I did…I ran wires direct from tailgate motor to the front. I swapped out the factory dashboard tailgate window switch for this switch which switches polarity as you press either direction.
https://www.amazon.com/gp/product/B01CIPUB0S/ref=oh_aui_detailpage_o05_s00?ie=UTF8&psc=1
I took a hot blue wire and the black ground wire from the connecter going to the factory switch and connected them to the new switch for power. Then ran 2 wires from motor directly to switch.
It works better than I expected. The problem is now the front windows wont work. Fuses are ok. There was another blue wire and another 1 or 2 ( don’t remember now ) wires that I just capped off. I’m assuming this is the reason the front windows are not working. So before I take the dash apart again I figured I would post a question here. What do I do with these wires?..should I just connect the other blue wire to the hot blue wire?
If anyone can help I would really appreciate it.
Thanks
Bill
Thanks
Bill
