Taking Bronco Offline - disconnecting cellular / telematics connectivity (Technical Discussion, Please)
edgeflyer
2013 FX4
My contact at Ford says there is a spot in the radio menue to turn it off. It really does disable it. I manage telematics for a large Ford fleet and have tested it.
SpringTXOR
The Woodlands, tx
1986 Bronco XLT
As long as it can connect to any network, then it is not totally disconnected from everything. Taking the SIM card out is the surest way to disconnect it from the cellular network, but it could still connect to an open wifi and upload.
GETSCHWIFTY
Rick Sanchez
Parts Unknown
2021 bronco
I may have got under the steering wheel and snipped off one of the ends of the three pronged fuses and inserted it back into fuse 19. No issues
bobogto
Chicago
M5
I never got to opening the panel, but I saw that 20 and 19 are shared. And 19 is ignition and I was wondering how that works. Now I know. Thanks.
Any annoying messages about it?
Scott R Nelson
Meridian, ID
I disconnected mine a few months ago using the menu. It can no longer do over the air updates and I can no longer open it or start it using FordPass. This is how I want it.
I think the number one annoyance was when I went off road and dropped the tire pressure to 20 psi, the FordPass app kept complaining to me about it and wouldn't forget that it had happened. It's slightly less of an annoyance that the car complains about low tire pressure every time I start it. The smarter way to handle that would have been to mention it once, then never again as long as all four tires have the same lower pressure. But apparently nobody on the Ford software team thought of that. Actually there are at least half a dozen things that the Bronco nags about that I wish I could tell it to "never tell me that again".
Donkey
Tijuana
totalled
i
Under Settings/Connectivity/Connected Vehicle Features then turn Vehicle Connectivity off.
[/QUOTE]
Okay, but is it actually off? Or just Google 's version of "mostly off but we can still do it when we want"?
da_jokker
Jeep Wrangler JKUR
Yeah I use XM as well as Nav and personally enjoy Alexa.
Just wish ford allowed us to truly disable updates which they do not.
