- David
- Nov 5, 2020
- 69
- 239
- 164
- United States
- Bronco
- Base
So I'm debating if I should go with the manual, I'm like 95% set on it over the automatic but have some questions, especially when it comes to offroading. First vehicle I had was a V8 5.7L 5 speed Dodge Dakota single cab.
1) I've read on this forum that driving the Bronco manual is different than driving a regular manual. What I have read on here is that you clutch in, change the gear, then clutch out completely and then push down on the accelerator. Is this true? Usually you have to balance both pedals at the same time when changing gears don't you? It's been a while since I drove a manual.
2) When going downhill, what gear do you stay in? Do you just put it in crawler or 1st and leave it there? This will ensure that the vehicle will not pick up speed correct?
See the video below for the kind of trails I plan on doing.
Also, any other tips on driving the manual?
