The 6G really isn't a rockcrawler.
Status
Not open for further replies.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
We all know this but some of us may be more stubborn and unwilling to fully admit it.
I went out again last weekend and tried to hammer a square peg in a round hole again and it just isn't working. It's not the IFS that's the problem, is the ground clearance. Everybody else on that trail with similar size tires had no issues because they had far more belly height.
Any mods done to overcome this shortcoming will take away what makes the Bronco so good at everything else. I'm done trying, I'm leaving it stockish from here out and going to build a toy for the rocks.
PWillette
Parrie
Maine
I would agree with your synopsis...there's some low hanging fruit for sure even with 37s.
Bmadda
Wisconsin USA
1990 Bronco eddie bauer
What kind of "issues" did you have? Mine definitely drags the skids in spots, but that's what they are there for. I just had to get over the "new" factor and send it!
Tricky Dick
Dick
PNW
What happens is the skids or sliders will ride up on something and unload the suspension then I'm sitting there like a turtle on a post.
It would take 5" of lift and 40s to match the belly height of the EBs on 35s I was with.
mattymik
Matt
Houston, TX
2019 Honda Odyssey, 2023 WildTrak
So the Wildtrak really is the better truck than the Badlands, then. :p
Benzo
Ben
Bay Area CA
too many to list
I agree with the limited bottom clearance.. This is the main reason why I am keeping my '70 EB crawler. I was hoping I could build a crawler on the 6G platform, but my money and time is better spent on the EB for the big rocks.
Dirty Bronco
Brad
Charleston
2021 Ford Bronco - 4 Door Badlands
@Tricky Dick Do you have any photos from the weekend? Especially any of the obstacles giving you trouble.
Tricky Dick
Dick
PNW
These are screen caps so the quality isn't great but you get the idea. Had to be pulled off this log, and the rock pile is where I had to turn back.
Tricky Dick
Dick
PNW
SS Bronco
Shayne
Loomis CA
2021 Bronco , F600, F5, LJ20
That’s to bad you are experiencing difficulties. Can’t speak for the 2 doors but 4 door 6G can do very well on rocks. On the big granite rock trails of the Sierra's and Moab slick rock the hardest things is just use to the dragging the belly. Hopefully some more time in your new ride will get to feel more confident. Great looking 2 door by the way.
Snacktime
Nate
Sac-a-tomatoes
Bronco, F150
I went max lift on my second Bronco and full armor. I will say my Metalcloak ate up some clearance, but has been why I have slid over certain rocks. I would say the biggest draw back is ground clearance.
Getting denied on rocks like that you getting into a more trail oriented rig with a trailer.
Tricky Dick
Dick
PNW
Rock crawling is more of a spectrum though, isn't it? You're coming to understand the limitations of your rig.
It is, but just comparing to other 35" class vehicles it's bad at it.
gmoney
Grant
'22 4-DR Bronco - Cyber Orange
This is one pile I did make it over after trying at least a dozen different lines.
Huh this doesn't look like it'd be much a problem at all. I'm a total novice when it comes to rock crawling, but we went over much bigger obstacles then this at the Bronco Off-Roadeo in Nevada
Tricky Dick
Dick
PNW
Status
