The articulation is there for the Bronco
Razorback
Bill
Dallas
Lincoln MKX
First and foremost, I think many (not all) in the Jeep camp forget competition is good for everyone. Without the Bronco, I don't think they have the 392 or the Extreme Recon. Plus any improvements going forward. I think without a doubt the Bronco rides much better than the Jeep. I think "with" a doubt the Jeep articulates better. There's been such a vocal chorus that the Bronco can't flex, that we've just accepted it without really investigating. Because of past technology and IFS it was easy to give Jeep that one...
But I was watching Town & Country when they said the Bronco was designed with more articulation than the Jeep...I about came out of my seat to hit rewind since I was sure I heard it incorrectly. When I heard it again I had to fact check. I knew the stock Bronco has done several Bajas, and I knew it had been to KOH, heck I've watched all the testing videos on the Rubicon and Moab, but I couldn't believe someone said the Bronco articulated more than Jeep... well, I found this and just wondering what others think (keep in mind competition is good and both are exceptional vehicles)
Per autoweek.com
Ford says with the front bar disconnected two-door models to score an RTI of 700 on a 20-degree ramp. And four-door models are projected to score a lower RTI of 620. So, compared to the Wrangler Rubicon Unlimited which scored 693, a Bronco’s articulation is very close. (The Rubicon score is with stay bar disconnected also)
In extreme situations I still expect the Jeep to flex more, but I don't see it as pronounced as some would lead you to believe...
Gamecock
Why would it suddenly flex more in an extreme situation compared to the ramp test? The flex is the flex...and Badlands is a bit better stock. That said, the advantage of the Jeep comes in the ability somewhat easily add a longer travel suspension that gains a lot more articulation than a stock Rubi.
wilbersk
Sean
2023 Bronco Raptor
Do you mind posting the article from autoweek.com?
Razorback
Razorback
Bill
Dallas
Lincoln MKX
Razorback
Razorback
Bill
Dallas
Lincoln MKX
I figure since they used a 20% ramp, it's possible that Jeep starts to surpass the Bronco at a steeper ramp. Although it wouldn't leave room to surpass much...
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I do recall reading about this earlier. It's a paper victory, because nobody serious about articulation is going to leave Jeeps stock, and once you start lifting the articulation goes up massively.
But that's not my reason for buying the Bronco, I'm buying it for what it can do stock, the fact that I can leave it alone, in a reliable factory configuration, and have the best jack of all trades ever made.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
I remember seeing these numbers last summer and wondering why the 2-door scores better than the 4-door. Anybody?
dgorsett
colorado
F250, Mustang, Explorer
SFA has an advantage over IFS outside of articulation. When a SFA wheel drives over an obstacle the rest of the axle moves up and away from obstacles. When an IFS wheel drives over an obstacle, the spring compresses, and the rest of the front end gets closer to obstacles . I think this may be a bigger issue than articulation, but I'm still all in.
Broncolli
MD
'21 Back Diamond 4 door MIC
Does this mean I can park with my front tire up on the front of another Bronco or on a Jeep at the mall now?
Ford Bronco The articulation is there for the Bronco 1626726271040
dgorsett
colorado
Tricky Dick
Dick
PNW
Dads_bronze_bronco
08 JKUR / x_x 00 TJ x_x
Per autoweek.com
We’re missing what a two door Rubicon will do to complete the picture, and yeah easier on a Jeep to go bigger in this department, but my 2 door Badlands will flex!
