Googz13
Joe
New York
Subaru Forester
A wiring diagram would be awesome!
AGSOFFROAD
AGSOFFROAD
New England
agsoffroad.com
how did you route the cables going to the battery?
through the door, then through the hinge area?
The wiring harness goes from the compressor through our Modular Tailgate Pass-Through, giving you a water tight seal. From there, it is routed through the hinge using the factory wire loom to the interior of the vehicle (where the factory subwoofer is located). This is where you will need to extend the ARB harness from, and it is an easy spot to tie into upfitter switch. From there we ran our large power wires through the interior of the vehicle and exited through a grommet on the firewall.
JohnGalt
Tahoe, CA
2023 Defender 110
Thanks for the heads up, but I’ve already executed my ARB twin portable plan. Once my Raptor decides to leave Michigan and show up here, I plan to add a 12V external power port and lose the battery clips to make it plug and play. I’m seeing more pros than cons with the portable for my situation.
Vandy
Doug
Ford Mustang Toyota Tacoma
Any plans for an install video?
Dadsquatch
Brad
Chandler, AZ
2022 Ford Bronco
Awesome product! I assume if you have a tailgate table installed, the filter relocation kit and the power pass-through will be in the way and not work? Thank you.
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Very nice!
AGSOFFROAD
AGSOFFROAD
New England
agsoffroad.com
A tailgate table installed on the interior of the tailgate will not be affected by the filter relocation kit or Modular Tailgate Pass-Through. It will need to be removed to complete wiring, but can be reinstalled without an issue.
The Modular Tailgate Pass-Through with the Filter Relocation Kit installed only extends into the tailgate 3-4". Picture below shows the back side of Modular Tailgate Pass-Through with Filter relocation Kit installed.
Ford Bronco The best way to mount your ARB Twin Compressor - from AGS Off-Road IMG_3508.JPEG
F OR D
BD Green Machine
What about the weight addition? ARB twin is 20lbs, and assume the mount and hardware is 5+. How is functionality with the added weight, and did anyone try with a tailgate support?
A gen2 could also double as a tailgate support if you stretched it to the hinges. Love it though, interested in seeing some feedback here!
21BL2DR
JD
ohio
2021 BL 2dr, 2021 BB 4dr, 2022 BS 2dr, trifecta
absolute genius idea! sign me up for this mod.
