Paul Gagnon
Paul
Sherwood Park, Alberta, eh?
I think a heard a weird faint "snap" on startup a couple of times. I'll keep an ear out. Are you thinking malfunction or that's just how it is at these temps?
I think it is a malfunction of whatever the mechanism is that locks the steering column. From the sound and feel of it I would guess that it uses something similar to a drum brake but at this point it’s all speculation.
killaz05
Charles
Rockledge, FL
2021 Ford Bronco Badlands 2.7 Sasquatch
The idle time in the settings resets after the vehicle shuts off so it's almost useless. Ford App comes to life once you manually start the engine.
I had to go check and you are right, it resets after each start cycle which I think is silly. Hopefully Ford updates this over the air for those in the cold regions.
mikeymcbryan
mikeymcbryan
Mikey
Canada
BaseSquatch
Leave the key fob in the vehicle and it will run till it runs out go gas.
Tried that. Still only goes 30 mins unless you go into the settings and turn off the 30 min idle. (Which resets on each startup). If someone can find a solution on Forscan that would be sweet!
lasttj
Robert
'06 Jeep TJ, '16 Ford F150, '65 VW Beetle
That last photo is awesome!
Toccoa
Isuzu Rodeo Sport
I’m getting cold just looking at the pictures. 🥶
Ford Bronco The Bronco at -40F COLD WEATHER TEST 🥶 1640729530015
Seatmandan
Dan
'21 Bronco, '11 Ford Edge, '10 Ford Fusion Sport
Question: why are ppl "reporting out on" testing things that the automaker already tested- rigrously? do they not trust the automaker? Asking for a friend....
Paul Gagnon
Paul
I’m not quite sure what you mean by this question. There are many areas of cold weather performance that are inadequate. Most of them seem to be due to computer programming. It is one thing to test a vehicle in cold weather, it is a completely different thing to live with it in cold weather. There are things that you need to do to keep yourself and your vehicle alive in the cold that people who haven’t lived it will never understand.
604Bronco
British Columbia
www.bronco6g.com
MrGreen55
Kyle
Oregon
toyota scion xb
There was a video yesterday cant find the post now. The window got icyed over would not roll down in tell the ice was removed in the door.
Efthreeoh
Hummer H3T
No offense, but I'm happy not understanding everything. Just sayin'
Paul Gagnon
Paul
Not true. It will still ask you after 30 minutes. If you are not looking at the dash when it asks it will shut off.
esquared
PNW
'21 2.7 BD
Can the engine block heater be installed after delivery? I didn't get it on my build and am thinking of driving up to northern Canada soon and am realizing it probably is a good thing to have...
BrentC
Brent
Calgary, AB
2019 F150 Sport, 2021 Bronco Badlands
Any Ford dealer in Canada should be able to do that for you. I imagine many in ID and MT can do the same. Call around.
Paul Gagnon
Paul
I want to know about anything and everything that could potentially leave me stranded where it is cold enough to kill me.
