- First Name
- John
- Joined
- Feb 16, 2021
- Threads
- 10
- Messages
- 652
- Reaction score
- 832
- Location
- Houston, TX
- Vehicle(s)
- BL-non SAS, 2.3 auto
- Your Bronco Model
- Badlands
I’ve been wondering if there’s a way to add 35’s to the non-SAS BL and also not have to limit travel. Hopefully someone figures it out!Yes, you will potentially need bump stops or something to limit upward travel for the reason you explained.
All of these problems is the reason the stock BL has the “most capable” suspension from the factory, since Sas limits travel to prevent rubbing of the 35s…. But that’s only if you measure “capability” by suspension travel…sometimes what you want is travel, sometimes what you want is clearance, sometimes you can get both…
…And then there’s portal axels.
This is a very deep subject, with a lot of geometry and not-necessarily intuitive cause and effect… a lot, if not most, of the questions you’ve expressed have already been explained and litigated on this very forum… not to mention I assume numerous times on the Tacoma forum.
It’s pretty cool stuff…
