- David
- Jun 9, 2021
- 13
- 345
- 663
- St Augustine
- 2023 Base 2 Door, Manual, 2.3
- Base
Little out of sequence I was replying to Wetdog.
Glad I read this before buying. Doesn’t seem worth it for a 2.3L. How do you trust a brand that mixes stats between two different engines to sell a product.Yes, the 2.3L didn't quite see the gains that the 2.7L did. Keep in mind that every dyno reads a little bit different. We used an average between the 2.3L/2.7L to get that range.
If you run 87oct and switch to premium fuel, whether that be 93 or 91, your gains will be even greater than what you see on the graph!
Following!!!Just ordered mine! I will be the test dummy for the MT.
1. Does switching octanes affect motor performance over time w or w/o tune.Happy Turkey Day Everyone! Thank you for the support! We are here if you have any questions.
Reminder $100 Off Ends Monday Night!
If you guys are looking for bundles on anything else with this please message me as we have special bundle deals going on as well!
1. We recommend 91+ on maps 5+. If you want to run under then going to 87 etc is perfectly fine.1. Does switching octanes affect motor performance over time w or w/o tune.
2. Do you have a tune and exhaust bundle available. I’m a fan of borla and the deep throaty borla sound.
Sounds great!!1. We recommend 91+ on maps 5+. If you want to run under then going to 87 etc is perfectly fine.
2. Yes we do I will shoot you a message!
One other question. Will this be pretty similar to the ford performance tune given the limitations of the motor ?Sounds great!!
I was always told to stick with an octane for the life of an engine. Is this an old mechanics tale?
Sounds great!!
The ford performance tune will most likely be a flash where this is a plug n play module. Will it net similar results? yes but this will be easier to install and non traceable.One other question. Will this be pretty similar to the ford performance tune given the limitations of the motor ?
Any chance you can extend the $100 offer till Christmas?Happy Turkey Day Everyone! Thank you for the support! We are here if you have any questions.
im on the fence myself about itAny chance you can extend the $100 offer till Christmas?
