- Chris
- Mar 6, 2021
- 61
- 3,872
- 4,380
- Cold Spring, NY
- 2021 Bronco, 2020 Ranger
- Black Diamond
So, without the app is it defaulting at top gains?
Install was super easy. Once you swap out the spark plugs the module itself is basically just disconnecting and reconnecting a couple pigtails. Still no app but you can change the tunes on the module itself.Yours is the first review that I have seen. How was the install? Any hiccups? Any luck getting the app?
Anyone else have any feedback?
I don't remember which is default but there's a display and buttons on the module to change which one it uses.So, without the app is it defaulting at top gains?
Oh. I didnāt realize that. I guess I should open the box. Feeling like today is a good day to teach my 8 year old son how to change spark plugs.I don't remember which is default but there's a display and buttons on the module to change which one it uses.
Not that I've been able to find.Alright, spark plugs and module are installed. Going out for a test run shortly.
Is there any documentation explaining what each setting 1-5 does?
What plugs do you go to? Just curious even though I don't have the 2.3 L myselfInstall was super easy. Once you swap out the spark plugs the module itself is basically just disconnecting and reconnecting a couple pigtails. Still no app but you can change the tunes on the module itself.
They include a set of NGK 1 step colder plugs with the moduleWhat plugs do you go to? Just curious even though I don't have the 2.3 L myself
I have mine sitting & ready to install once my Bronco comes in! Can't wait to hear your feedback on this. Is your Black Diamond still on factory tires & what rear end do you have?Alright, spark plugs and module are installed. Going out for a test run shortly.
Is there any documentation explaining what each map setting 1-5 does?
4DR with 4.46 and 7MT. This thing rips now. Wow. Iām impressed. It really wakes up first and second gear. I didnāt get on a highway yet - but, I was hitting 75 MPH rather quickly. Upgraded suspension and 285x75 Toyo in the spring. So, for now itās stock.I have mine sitting & ready to install once my Bronco comes in! Can't wait to hear your feedback on this. Is your Black Diamond still on factory tires & what rear end do you have?
good to hear!! I ordered the 4.27. Rear end & Iāll be throwing on some 33ā tires. Not sure if I should break the engine in before installing the module?4DR with 4.46 and 7MT. This thing rips now. Wow. Iām impressed. It really wakes up first and second gear. I didnāt get on a highway yet - but, I was hitting 75 MPH rather quickly. Upgraded suspension and 285x75 Toyo in the spring. So, for now itās stock.
I would suggest waiting. Youāre gonna easily push it past the suggested 3500 RPM with this module.good to hear!! I ordered the 4.27. Rear end & Iāll be throwing on some 33ā tires. Not sure if I should break the engine in before installing the module?
i was thinking about installing around 1500 miles. You can get the 10 speed auto with a 4.27 rear end with locker as an optionI would suggest waiting. Youāre gonna easily push it past the suggested 3500 RPM with this module.
Which model has a 4.27?
