Thermometer issue: outside temperature showing 118 degrees and it’s really 64
cscottp67
cscottp67
Richmond TX
19 F-250 / 20 f-150
The temp sensor probably came loose and is close to something that's that hot. They are usually connected somewhere down by the radiator. Look around for any loose sensors.
Will look thank you!
cscottp67
cscottp67
Richmond TX
19 F-250 / 20 f-150
No that’s not the compass degrees. It read the same on the instrument cluster behind steering wheel. We watched it steadily rise from the right temperature all the way to 122°
ac360
Here/There
None
Sounds like the temp sensor maxed out to its max rated spec. This types of failure happens to all analog sensors when the circuit is completely opened or completely closed.
Completely opened means the wire is disconnected/cut, or the sensor failed into an open state internally.
Completely closed means the wires are shorted, or the senor failed into a shorted state internally.
cscottp67
cscottp67
Richmond TX
19 F-250 / 20 f-150
Incinr8
1973 Dodge Power Wagon
I'm not a math scientist. so suck it. lol.
Hey19
JJ
Bethlehem
Interesting bug. Mine could never keep the proper time for a while. Manually set it and come back to it being different. Set it to auto mode and it would be something different. Played this game 3-4 times and now it has been correct all week.
If the sensor is in the mirror, the door connector shouldn't be in play?
MayhemMike
Mercury
Looks like you were jamming to a song of The Who’s Tommy album.
Happy
Jerry
Missouri
CJ5, Wagoneer
does disconnecting the battery for a while then re-connecting do anything for the temp setting?
