Tie Rod Reinforcement from Zone Off Road
BigGarnet
ā€˜21 Bronco
jxc
Joe
Chester County, Pennsylvania
Accord/CX-5/A5 Cab
The weak point then moves to the steering rack -- which is a lot more $$$ to replace. -- so maybe go with this sleeve and Bronc Buster's rack fix. ( You're still in for $400 - but you get both ). I'm not sure where the failure point is after reinforcing the rack. Probably some 5K$ part...
BigGarnet
ā€˜21 Bronco
It seems the racks are only breaking when the truck is lifted more than 3ā€. Have you seen a stock or equivalent Bronco with 35s break a rack?
The lift changes the angle and allows for that failure. Most of the broken rack reports were also the guy selling the rack fix bushing for a crazy price…so I’m not sure how bad it really is.
1979
Baltimore, MD
This. There’s a consensus on this forum that the rack is weak. The only one I’ve seen fail is a guy on 40s driving like a maniac, intentionally trying to break the rack. I mean, I could break all kinds of shit if I was trying to.
jxc
Joe
Accord/CX-5/A5 Cab
I have not - Bronc Buster is the only one I've heard of.
Rkgzx9leftcoast
Robert
Scottsdale AZ
Jeep JL
I bought the ones from JKS, same company....they are nicely made. Not sure if they will provide same reinforcement as broncbuster. Don't have my truck yet...supposed to be in transit. When I get I am going to install these, and the bronc buster internal sleeve. If you watch his video, he shows how it fails. It's internal lateral movement in the rack, the sleeve eliminates it. Anyone who is going to off road these trucks should invest in these fixes. Compared to new rack....
wyobronco
Clint
Wyoming
'21 Bronco, 94 Land Cruiser, 02 F-250, 16 Explorer
I just purchased this and the broncbuster bushing. Ill be running 37s on an icon lift. I think it will work well, and its a good solution as a first step. Big thing about a rig like this is now when to stop what you are doing. Stay out of those full bind situations. Ill be installing it all over the next week then heading to Moab, so Ill let ya know!
Cable Guy
Kurt
Audi RS7
Amen. I could run mine into a bridge embankment at 75mph claiming I’m looking for ā€˜weak points.’ Garbage content.
Razorback
Bill
Dallas
Lincoln MKX
Not to go off topic...well sort of, but I'm looking at the icon suspension as well. Which stage are you going with? I plan to overbuild so stage 8 might be in Buddy's future. But their system just makes more sense to me than Fox and King as I research.
Mattwings
Matthew
Northville, MI
2021 Badlands Bronco
Vehicle Showcase
I am on stock 33s and this looks like a good upgrade to me. I have only seen one other rack break on video, but it was a stock SQ model and relatively light wheeling, crossing up on a log feature at an off-road park I think. I look forward to some ride reports!
wyobronco
Clint
Wyoming
Im just going with their spacer kit right now. Things are way too new to jump into a bunch of coilovers and whatnot for me. I have a feeling down the road when Im done using this as a daily driver I might rip it all apart and go 1-tons.
After talking with Dusty, the spacer kit should do really well and MOST of it, and let me decide down the road what I want to change.
BigGarnet
ā€˜21 Bronco
You sure that one was the steering rack? I thought that was just tie rod breakages as well.
Mattwings
Matthew
Northville, MI
Vehicle Showcase
Sorry, yes, tie rod, not rack. Seems pretty clear the rack issue is related to lift and steering angle. I have no lift plans, but adding some strength to the tie rod sounds like a reasonable upgrade for my use.
dan79
dan
ma
08 f250
i did the icon 3 and planned on running 37s too
vrtical
Doug
GSMNP, TN
Fords
rack issue is at full drupe (extended more if lifted) it darn near pulls splines completely out, that is what the rack insert fix prevents from Bronco Buster. The OEM tie rods are are pretty light as a fuse, I think you would be ok putting a bit stiffer ones in, just dont go hardcore, that will just move the failure elsewhere.
