Tips to install Ford tailgate table
broncosor
2022 Bronco Badlands
So I got the Ford tailgate table for my freshly delivered 22 Badsquatch, and one for my buddy’s also freshly delivered Bronco.
The Jacknuts that come from Ford are garbage and we broke 3 despite using a torque tool with half of the Ford recommended torque.
One broke from the thread before we could screw even half of it in…
Tips 1: tight those 4 nuts very gently. Less than what Ford says.
Some people on the forum got the same issue and drilled those out. We didn’t want to do that to avoid having a piece of metal fall into the tailgate for it to rattle when driving.
So here is tips 2:
Just put a piece of thin cord through the broken jacknut, then drive that rope out through one of the larger holes in the tailgate, next to your broken nut. Then use pliers to squeeze the jacknut inside. Your cord then catches it and you can then take it out from from the other bigger hole you got the cord out from.
For reference we bought those on amazon:
“Hillman 59126 Short Jack Nuts (1/4"-20) - 15 Pieces”
They are better than the Ford ones.
Our tables are now mounted properly.
We plan on doing a lot of overlanding with both our Badsquatch Broncos, so follow along if you want on IG at @broncoexplorers
TheShark
'24 Bronco 2DR Heritage Edition Limited,'25 Maverick Lariat Hybrid AWD
Nice tips, I too ended up getting the Hillman jacknuts, big difference, the ones that come with the table are junk.
WuNgUn
Ontario Canada
2 door Squatched
So here is tips 2:
Did you maybe cross thread the jack nuts?? Had no issue at all with mine, but I did notice they were easy to cross once installed.
JohnnyBronco
Pennsylania
X4
There is an aftermarket table that uses existing threaded holes with no drilling. And rated for more weight and less rattle
patch1103
P.
Chicagoland
2017 JKU 75th Anniv. Edition
So here is tips 2:
Great tips! I'm going to replace the remaining three jacknuts (already replaced one) and will be using this advice for removal.
TigerBronco
Charles
2011 F-150 F/X 4, 2019 Honda Odyssey, 2001 Nissan Pathfinder, 1992 BMY M923A2 M
Brett
Oregon
Bronco, Mustang, Thunderbird
So here is tips 2:
Could you go into depth a little more or explain a different way? Im still having trouble understanding how to remove the jack nut. Like you, I’d like to remove It without drilling if possible.
