Tire Pressure concerning OEM 35” Goodyears
abeabeabe
Abraham
Austin, TX
2019 Subaru Crosstrek
One thing I noticed is that the door placard sticker recommends 39psi (cold) on my Sasquatch base. 39 psi cold could easily creep up to 45-48psi with some heat and/or lower elevation changes. However, the sidewall of the tire says 35psi (cold) is the max pressure. Why would the door placard suggest 39psi when Goodyear has a 35psi max on the sidewall. Attached are both images I took.
webspoke
Stan
Pilot Point, TX
F450, GT350
On the tire it does show up to 10psi additional is allowed (top line). Looks like ford is using that exception.
VoltageDrop
Fidalgo Island, WA
23, 69 Bronco
The sidewall doesn't exactly say 35 is the max pressure. Read it again, including the first line.
RagnarKon
Bryan
New England
Ford Bronco, Escape, Focus
The tire sidewall isn’t telling you the maximum inflation pressure, it’s telling you the maximum load rating when the tire is inflated to 35 PSI.
Which is on the low side for a light truck tire. Must be a squishy tire.
TacocaT
Curtis
Seattle Washington
17 Explorer Platinum, 15 Roadglide, 12 Duke 1199
Use the door info. The PSI on the tire is @Max load rating. Unless you plan on loading your rig with an additional 5000lbs of gear, you're fine.
Roll Sound
Hollywood
2021 Wildtrack 2DR MIC OW, 2014 KTM RC8R
35psi probably pretty close. I'm bringing a digital gauge with me when I pick up my truck. Many say the delivery pressures are pretty high.
Efudd
Ernie
F350 Tremor
They also might be saying 39 psi to improve mpg over a 35 psi tire
chobit
Eddy
Seattle
Mini Cooper SE, MIata ND2 GT, Bronco Badland SAS
Anyone has a chance to do that chalk test? Just curious what psi everyone is using?
kodiakisland
Arkansas
12 Tacoma, 18 Indian, 23 GV70
You’re not reading the sidewall correctly.
ProdigyJKU
Rob
2012 Wrangler
39psi is for a fully loaded vehicle. Since I'm usually alone in it with little cargo, I run mine at 35psi.
Happy
Jerry
Missouri
CJ5, Wagoneer
Just did chalk test on 315/70/17 Mickey Thompson Baja Boss AT.
32 PSI is where they will run for a while.
