Tire Pressure Monitor Error after Inflation
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
So I tested my EZFLATE hose system and External pump today in my buddys driveway. Everything worked great, from deflation to inflation.
Then after inflating all tires to 35psi......the right rear was showing 35, BUT still had that "low pressure" orange warning symbol on it. I tried truing off/on ignition and driving around even....still shows fault....AAAaargh....
Anyone have a remedy for this? Or will it go away after a while?
da_jokker
Jeep Wrangler JKUR
I had the same issue with my Jeep. I had to over inflate what I wanted just to shut up the alert and then drop the pressure back down. Sometimes you can get away with driving it to heat up the tires which will push it over the edge enough to shut up.
The fix is to lower the alert cutoff... I'm assuming you can do that via forscan, at least I hope so.
Tricky Dick
Dick
PNW
www.TD-Distributing.com
I'm not sure what his BB is but I'm guessing it must be 36 like my BL since my suggestion worked. I dropped it to 32 with Forscan to make this go away.
Rjhoefar
Roy
2022 bronco badlands
I dropped mine today to 28 with forscan. Pretty easy fix if you're familiar with forscan
SROC3
SROC3
Pat
Las Vegas, NV
Ford Bronco 2022
Thanks again everyone! :) I literally just pumped it up with my bike pump and it disappeared after 37 psi :). Easy peasy!
