Tire size
Mjmcknight0
Clearwater
Jeep Grand Cherokee
I put on terra grap 285/70/17s I measured the exact circumference (2618), I put that into forscan and my Speedo is still off. What number has anyone else used?
wyobronco
Clint
Wyoming
'21 Bronco Black Diamond 2 DR
So you just measure the outside circumference and change that in forscan?
F1NDx
Detroit, MI
Had similar issue.
Running BFGoodrich All-Terrain T/A KO2 - 265/70R17....4475mm was dead on for me.
(Tire calculator said 2520mm).
Dingbat
Western Northern Cackalacky
Cars, bikes, canoes, sailboats…
Tires deflect under load so the outside circumference can be too large. Did you try marking the tire and measuring out one revolution on the ground?
